Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 08-02-2012, 21:46
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
PWM + Jaguar
Is the a good (and legal) way to keep the pwm's in the jaguars. Ours keep falling out. Electrical tape?
Unread 08-02-2012, 21:52
Zembas's Avatar
Zembas Zembas is offline
AKA: Jonathan Oishi
FRC #0359 (The Hawaiian Kids)
Zembas is on a distinguished road
Re: PWM + Jaguar
In 2010 we used electrical tape to hold our pwm cables in their respective jaguars. The tape still holds even now. I think some teams have mentioned gluing their pwms in.
Unread 08-02-2012, 22:14
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: PWM + Jaguar
We hot glue all the PWM wire down to jags, victors, and spikes. For good measure.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 08-02-2012, 22:22
Re: PWM + Jaguar
There are wire clips built into the Jaguars, just in front of the connectors.
Unread 08-02-2012, 22:24
FRC #4174
Re: PWM + Jaguar
So how do I work them. I push my pwm's in and they fall easily.
Unread 08-02-2012, 22:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: PWM + Jaguar
+1 To the wire clips. They really work well and they're already there. And they're not nearly as permanent as hot glue. And the provide strain relief as well, which is neqarly as important.
Unread 08-02-2012, 22:30
Re: PWM + Jaguar
See the little hook thing on the front edge of the Jag, just in front of the PWM connector? Push iin your PWM connector, then slide the wire under the hook and pull it till it's very slightly taut and pulling down your PWM.
Unread 09-02-2012, 08:20
Re: PWM + Jaguar
A,
If you can, use a wire tie to secure the PWM cable close to the base of the controller. As such it is pulled tight by the wire and can't pull out. The Jaguar provides this for you. Simply slip the PWM cable into the wire holder on the front edge.
