Go to Post FIRST is an amazing combination of principles that, when applied to the world, has had a monstrous effect on the way High School students learn, think, and relate to others. - Amanda M [more]
Unread 08-02-2012, 22:35
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
[UPDATE]Custom dashboard - multiple cameras and sockets
This is a update to this thread
http://www.chiefdelphi.com/forums/sh...d.php?t=100675
We have been working on a custom dashboard system that uses sockets to connect to the robot, recive data and dynamicly display the data using one of the UI elements that we created. It also allows you to stream as many cameras as you want (limited only by the amount of ports on the router) directly to the dashboard, therefor bypassing the laggy crio. We were doing this all without any lag. Except for the MJPEG steaming code, the code is 100% original. Here is a video of it in action.
http://www.youtube.com/watch?v=0RYutNnbB6g
Updates since last post:
Network communication finished
Able to recive and parse all the data from the bot instead of just one value
UI Elements mostly finished
Streaming Cameras
Data managment system finished.
UI Elements
2D Asix Position
Bar graph
Graph
Camera
Dial (gyro)
Light (status light)
Speedometer
Text
TextField
src: (dosent include the server code (robot code) yet.
https://github.com/Wildcats3540/Dashboard
Unread 12-02-2012, 20:44
Intel i7 Intel i7 is offline
Team Role: Driver
Intel i7 is an unknown quantity at this point
Re: [UPDATE]Custom dashboard - multiple cameras and sockets
I uploaded the robot code to our github
https://github.com/Wildcats3540/Dashboard_Robot
Driver
Programmer
Webcoder/Designer
http://www.chiefdelphi.com/forums/showthread.php?t=102329
Making our own custom dashboard system/framework!
