Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 08-02-2012, 23:36
Thundrio Thundrio is offline
Dedicated Racer
FRC #3673
Thundrio is on a distinguished road
Use of the Line Following Sensor from last year?
We are using a belt to run basketballs up to the shooter part of our robot for this year. We are planning on using the line following sensor from last year to determine when there is a ball in place. Mechanical insists that it is possible (and I think it is too), but I am not sure how to do this exactly.
Any help or ways to get me started would be useful.
TYIA
Interested in a new way of playing old games?
visit http://www.speedrunslive.com for a way to make single player games multiplayer!
visit http://www.zeldaspeedruns.com to open up a new world for zelda lovers!
pm me here or at zsr for more information!
Unread 08-02-2012, 23:49
Intel i7 Intel i7 is offline
FRC #3540 (Wildcat Robotics)
Team Role: Driver
Intel i7 is an unknown quantity at this point
Re: Use of the Line Following Sensor from last year?
Maybe a limit switch or even sonar sensors would work better, line trackers tend to be unreliable when there isn't a big light difference and when the lighting isn't exactly right
Driver
Programmer
Webcoder/Designer
http://www.chiefdelphi.com/forums/showthread.php?t=102329
Making our own custom dashboard system/framework!
Unread 08-02-2012, 23:57
Dedicated Racer
FRC #3673
That's my thought too, although the mech head insists it can be done, so I will show him for tomorrow, and we can see.
Thanks for the advice though, and I think I figured out the code anyway.
Unread 09-02-2012, 00:21
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Best thing to do would be to set up a line sensor, plop a ball in front of it, and play with the line sensor adjustment to see if you can reliably get it to detect a ball and not anything else. It won't take long at all and it'll give you a definite answer. Please let us know what you find out
Unread 09-02-2012, 00:26
Team Role: Driver
The best way that I can think to do it is it you put some sort of light near the sensor so your not relying on ambient light which will always be changing
Driver
Programmer
Webcoder/Designer
Unread 09-02-2012, 00:29
AKA: JD Russo
The sensor has its own IR emitter.
Unread 09-02-2012, 00:32
Team Role: Driver
Oh, right what am I thinking. Too late at night lol. There are still a lot of other variables tho, but I would be interested to see your results from test. Our team will probably be using limit switched tho is i think it will be more reliable
Driver
Programmer
Webcoder/Designer
Unread 09-02-2012, 00:35
AKA: JD Russo
Happens And yes there definitely are, the biggest problem I'd see with it would be ambient light interfering with it, and the spherical shape of the balls. You'd probably need to make some sort of dark chamber for them to pass into with the line sensor.
Limit switches would probably be my preference too, as with that kind of mechanical solution there seems to be a lot less margin for error (unless the squishyness of the balls presents you with issues triggering it or something), and with something like ball collection where accidentally grabbing extra balls could cost you a penalty, I'd rather be safe than sorry.
Unread 09-02-2012, 00:37
Team Role: Driver
Also, not to mention the black lines on the balls might cause some problems.
Driver
Programmer
Webcoder/Designer
Unread 09-02-2012, 00:39
AKA: JD Russo
Yeah, that too. It really just doesn't seem like a very appropriate use for the line sensors; sure, you might be able to shoehorn them on, but does it make sense?
