Go to Post Wait, does this mean TV isn't real? I'm shocked and appalled. - s_forbes [more]
Unread 09-02-2012, 11:37
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
# storage tanks
Is there any number limitation for storage tanks of pneumatics ?
And In previous years we received Clippard storage tanks with the kit. Are we still allowed to use them on the robot ?
Thanks in advance.
cil
Unread 09-02-2012, 11:40
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Re: # storage tanks
There is no rule limiting the number/ capacity of tanks on the robot this year. However, if you do not have a compressor on the robot, it must be powered AND controlled by the robot. You can use previous years clipper tanks, provided they are COTS, which they are.
"No, you can't use the Kinect to do pelvic thrusts."
Unread 09-02-2012, 11:42
Re: # storage tanks
There is no limit on storage tanks this year.
Any storage tank speced for 125 psi working pressure can be used, provided you account for it in the BOM and it meets all other robot rules.
[R69]
All pneumatic components must be COTS pneumatic devices rated by their manufacturers for working pressure of at
least 125psi (with the exception of [R71]-D).
Unread 09-02-2012, 11:47
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: # storage tanks
As many as you can stuff into a 38x28x60 box
Unread 09-02-2012, 11:53
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: # storage tanks
If you are not running (or even if you are) a compressor on board test to see how long it takes to refill your tanks and compare to the amount of time between matches during elimination rounds. You don't want to have a function failure because you didn't have enough time to "re-charge".
