Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 04-01-2003, 13:59
Lauren Hafford Lauren Hafford is offline
#0159 (Alpine Robotics)
Lauren Hafford is an unknown quantity at this point
Send a message via AIM to Lauren Hafford
Suction Cups
Sorry, I have another question:
Can we attach to the walls or floor of the platform? As long as we don't damage it?
lauren
Added: is the HDPE considered the framing? Because if you attached only to the smooth polyethylene, not the ramp or acrylic or anything else would that still count?
Unread 04-01-2003, 14:13
FRC Key Volunteer Trainer
AKA: CrazyNate
GM28 Robots may not intentionally:
· Detach Parts (no connection at all to a robot);
· Remove the lids from the containers;
· Damage another robot;
· Tip over another robot;
· Attach themselves to the ramp mesh or framing material;
· Attach themselves to the railings/walls of any field structure.
Emphasis added where needed...so I'm going to say no on this one...
Nate Smith
nsmith@smythsoft.com
Unread 05-01-2003, 17:07
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Rule GM31
The outer field barriers are safety features of the playing field and robots should not be designed to react against them. Reacting is grabbing or using the top of the field borders, the top of the driver stations, the top of the pipes at midfield, and the top of the platform/ramp polycarbonate sides with the intent of supporting a robot or robot part. It is also unacceptable to grab onto or push hard enough against multiple surfaces simultaneously in order to wedge and make immovable a robot. Contact with all of the barriers is acceptable. Pushing a container against a barrier is acceptable if the forces applied are not sufficient to damage the barrier or otherwise deform the playing field. Minor forces associated with activating contact sensors carried by the robots or similar minimal-force contact methods to detect and locate the field barriers are permissible.
If you're thinking about attaching to the HDPE platform, this rule could possibly prohibit it. You cannot attach to the top of it.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 05-01-2003, 18:13
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I think this rule refers only to the clear polycarbonate sides. you cannot touch the top of the walls on the platform, but there is no rule that says you can't attach to the HDPE platform itself.
Jeff Waegelin
Unread 06-01-2003, 00:01
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
I agree with Jeff
I think that the way that GM28 and GM31 are worded means that we can attach to the HDPE surface.
Just my opinion, though. I assume that FIRST will clarify this.
Andy B.
Best use of suction cups in Galieo? Spikey Championship Event 3 21-04-2003 20:36
pic: Team 870 Suction Cups CD47-Bot Robot Showcase 45 29-03-2003 22:48
Q&A Discuss: Suction Cups CD47-Bot Extra Discussion 14 27-03-2003 18:04
Image Discuss: Our anchor is more powerful than you bot CD47-Bot Robot Showcase 31 22-02-2003 21:00
More clarification on the suction rules Natsume Rules/Strategy 7 15-01-2003 01:04
