Go to Post note to self: do not use robot to retrieve cars from water. - Greg Marra [more]
Unread 27-01-2012, 10:52
dkearle's Avatar
dkearle dkearle is offline
Dianne
FRC #1280 (Ragin' C-Biscuits)
dkearle is an unknown quantity at this point
Sending SmartDashboard Data to cRIO without pressing [ENTER] key
Hi,
Our team is attempting to tune a PID controller using the SendablePIDController and corresponding widget on the SmartDashboard. We ran into a little problem last night. We successfully displayed the widget on the dashboard. With our robot enabled, we typed in a new P constant on the SmartDashboard and then hit the [ENTER] key, which immediately disabled our robot.
Last year on the driver station the space bar was used to disable the robot. This year it is the [ENTER] key.
Does anyone have a solution on how I can enter data into the SmartDashboard triggering the SmartDashboard to recognize the new data and send it to the robot, without me using the [ENTER] key on the driver station? I don't want to keep inadvertently disabling my robot when I'm trying to see the effect of a new P constant in my PID controller.
Thank you!
Dianne
Unread 28-01-2012, 00:49
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
Re: Sending SmartDashboard Data to cRIO without pressing [ENTER] key
<removed>
Unread 28-01-2012, 09:41
PranavSathy PranavSathy is offline
Team Captain
AKA: Pranav Sathyanarayanan
FRC #0263 (Sachem Aftershock)
PranavSathy is an unknown quantity at this point
I have no personal experience with SmartDashboard, but since last year my team uses the UDP on port 1140 (if I recall right?) to communicate with a custom dashboard we make in C#, and if you check out the Team Update on the 24th of January, I believe the port for Dashboard to Robot communications is UDP 1150, you can, without much effort, create a C# dashboard to communicate with the robot using UDP .
I know my answer is not 100% relevant, but if you do not manage to find your answer than I hope this is of help to you. Good luck!!
This is MADNESS!
NO...
THIS...
IS....
FIRST ROBOTICS!
Unread 09-02-2012, 08:53
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Since this thread is about SendablePIDController and the original poster seems to have figured it out, can you help us please?
We are using the IterativeRobot instead of the CommandRobot and we are trying to get the SendablePIDController to work on our Smartdashboard so that we can tune our speed encoder on our shooter.
We started yesterday by putting this in our class init:
SendablePIDController *speedControl;
Then in our constructor we put:
speedControl = new SendablePIDController(0.0,0.0004,0.0, speedEncoder, shooterMotor1);
This worked fine as a PID controlled system, our shooter is obviously under control, we just want to tune the system real time. How do we get the SendablePID menu to show up on the dashboard? I know it has something to do with PutData() but nothing I try compiles. I have tried this so far in the constructor:
SmartDashboard::GetInstance()->PutData("SendablePIDController",SendablePIDController::GetInstance());
I have never gotten the hang of all the "->" and "::" with C++, I am a visual basic pro hacking C++ so make no assumptions of what I know.
Thanks
Unread 09-02-2012, 15:07
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Originally Posted by dkearle View Post
Hi,
Thank you!
Dianne
I entered a bug report for this (http://firstforge.wpi.edu/sf/go/proj...d/tracker.bugs) on the FIRST Forge project site for the Smartdashboard. I was able to get around this problem by running the driver's station on one laptop and the smart dashboard on a second laptop. However, it still didn't really work out for me because there was still something funky going on with the PID tuning. Whenever i tried to set the setpoint for the PID it would go to zero. Not sure if this was a side effect of running in the two laptops configuration.
Unread 09-02-2012, 15:11
Originally Posted by sircedric4 View Post
It should be:
SmartDashboard::GetInstance()->PutData("SendablePIDController",speedControl);
Unread 09-02-2012, 15:33
sircedric4's Avatar
AKA: Darren
Originally Posted by jwakeman View Post
It should be:
Thank you, that compiled! We'll give it a try tonight or tomorrow night to make sure it works at runtime.
Unread 18-02-2012, 02:29
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
bump bump bump
Has anyone found an acceptable workaround for the Enter = disabled bot issue?
We don't want to have to use two laptops at every match... I'm hoping I don't have to dig through the smartdashboard code to make a fix myself. Anyone?
http://team2168.org
Unread 18-02-2012, 11:35
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
Yeah, big problem for me too... A fix would be much appreciated (even if it is quite hackish...)
Unread 20-02-2012, 12:58
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
It should be:
So you were able to get this to work? Even with the new WPILib we still got a crash at runtime. Don't know what the problem is. I didn't *see* any SmartDashboard initialization or anything we needed to do...
Unread 20-02-2012, 20:40
otherguy's Avatar
sparkE
AKA: James
For any teams looking for a solution to the treads original problem, it looks like Team 694 developed a solution in their bug report:
At the moment, the only way to commit a change made in a text field of the SmartDashboard back to the robot via the
NetworkTable is by typing in the new value and hitting <Enter>. However, this also happens to be the key binding for
disabling the robot in the 2012 Driver Station, thereby making it inconvenient to use the SmartDashboard's capability
for sending data to the robot.
Our team's solution is to update over the NetworkTable if the Text Box loses focus; in other words, the robot gets the
field's new value after the user inputs data and either clicks outside of the SmartDashboard's Text Box or presses <TAB> .
See their bug report on the SmartDashboard First Forge page for the diff attachment
http://team2168.org
Unread 15-03-2012, 14:57
Programmer
AKA: Joe Grinstead
Alright, I've created an extension which will simulate the enter key being pressed on the SmartDashboard when you push a button.
To use it, download the attached .zip, pull the .jar out of it and put it into "\Program Files\SmartDashboard\Extensions", then run the SmartDashboard.
Select "View/Add.../Enter Key" and there will be a button you can use.
Unread 15-03-2012, 22:37
FRC #4174
Oh wow, that's awesome! I thought I was totally out of luck, but I guess not.
Suppose you've tried binding this action to a key? Because that would make it even more awesome.
Unread 15-03-2012, 22:56
FRC #4174
And then I noticed this. I'll try that now.
Unread 16-03-2012, 16:09
FRC #4174
Alright. So I patched the dashboard, but I don't have a robot I can use. Can someone test the file for me?
