Go to Post Load the whole bot up with all 22 motors, put them all into the drive train. Oh yes. - Grim Tuesday [more]
Unread 09-02-2012, 15:12
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Remember to use washers and not over tighten
Originally Posted by Peter Matteson View Post
Thats what happens when you use the wrong fastener for that function.
You should use Riv-nuts/Rivet-nut/Clinch nuts in that type of situation to prevent that possibility of that happening. In industry that is called mistake-proofing because the failure is inherently by design.
http://www.mcmaster.com/#standard-rivet-nuts/=g6da7w
I've been fighting to use rivet nuts for some time and out head Coach/Advisor just didn't believe that they were robust enough. So the other day when one of the other mentors was saying how their sub-team wanted to use them but were being over-ruled I devised a little test to show that they won't pull through.
In this blog post on our website you'll see a picture of a properly installed steel rivet nut from Mc-Master http://www.mcmaster.com/#95105A127 that was subject to attempted destructive testing. It was installed properly and a bolt threaded into it. Then we placed it in the hydraulic press and proceeded to push on the bolt from the back side. The 1/8" aluminum that was over an aprox 1.5" x 1.5" hole deformed first, once it started to tilt the bolt then deformed but there was zero sign of the rivet nut wanting to push through the material.
