Go to Post So I guess this is just another case of someone reinventing the leg? - petek [more]
Unread 09-02-2012, 15:20
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Robot Speed Rules
Is there any rules in regards to the max speed of the robots. We are thinking our robot goes pretty fast and strong and could cause some damage. Is there is a requirement on speed how do you slow it down. Our guess is in the programming, but being a rookie team using labview, we don't know how. Any help would be greatly appreciated.
jalmos
4166
Unread 09-02-2012, 15:22
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Re: Robot Speed Rules
To the best of my knowledge, there is not a speed limit other than to not cause an unsafe situation, and those imposed by Newton. Remember, the court isn't actually that long, and I have never heard of a team gearing a robot for more than about 15 fps.
Unread 09-02-2012, 15:24
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
There is no speed rule. Just don't tear up the field. If you aren't buring holes in the carpet your practicing on I wouldn't worry.
As a 10 year veteran trust me when I say you robot probably isn't as fast as you think. You will be shocked by the speed and cotrol teams have at the highest level.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 09-02-2012, 15:41
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
There have been a lot of teams gear for more than 15 fps. 2008 is a prime example of team gearing high. Many teams were geared for 18 fps and a few probably hit 20. (this is obviously freespeed and they lost speed on the floor)
Unread 09-02-2012, 15:45
Dusk Star's Avatar
AKA: Andrew
Good to know! still, my point was that the speed of the robot was fundamentally limited by the design constraints and Newton, not the rules.
Unread 09-02-2012, 15:50
I was not questioning your thoughts. I totally agree with your reasoning.
Unread 09-02-2012, 18:29
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
973 was geared for a little over 20(free-speed) in 2011. It's not uncommon to see teams shoot for that range, however it greatly depends on the game. For instance in 2010, it was very uncommon to see teams in the 16ft/s+ range because of the large bumps in the field. In 2008(as was mentioned before) a lot of teams geared high because it was basically a speed game. 148 even geared for 30ft/s, however later re-geared their robot to a slower speed.
jalmos, I highly recommend that if your team is shooting for higher speeds then you definitely use a 2-speed gearbox. The super-shifter from AndyMark is a good choice.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 09-02-2012, 21:44
Billfred's Avatar
Billfred Billfred is offline
Yes and no--this is generally a good idea in many standard drivetrains, but it is not something I'd advocate a team undertake with 12 days to ship day without a full appreciation of the issues.
This is JVN's mechanical design spreadsheet, which many teams have found exceptionally useful. Run your numbers and see where you stand--once you get much past 10 feet/second, you're requiring a bit more skill. (And mind that acceleration will be much more common this year thanks to the dividers and bridges; the faster you gear the robot, the more current you'll draw on each launch and while pushing. You're going to push.)
If you're using the kit drivetrain and you decide your speed is not what you want, I'd suggest changing your wheel sprockets (or output shaft sprocket, but double sprockets are harder to find). This is much easier than integrating all-new gearboxes, but it has the above-mentioned tradeoffs.
Unread 10-02-2012, 10:59
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
While there might not be any ruling about the max speed of your robot, be aware that high speed ramming is generally frowned upon. Don't get me wrong, it does happen. If you are zipping across the field to make a defensive stop, I typically encourage the drivers to take the speed down a notch just before interacting with another robot.
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - 2016 : 573 Mech Warriors: Mentor
