Go to Post Holonomic? I thought we were holographic. Or was that autonomic? I'm confused.... - Wayne C. [more]
Unread 06-02-2012, 17:34
yBother yBother is offline
FRC #2198
yBother is an unknown quantity at this point
Question Jaguar Programming with NetBeans
Greetings! We're trying to program our Jaguar, but it does not respond to the commands that we copied from the official PDF. Can someone please take a look:
Here's our codes regarding the Jaguar:
private testJaguar;
testJaguar = new Jaguar(1);
testJaguar.setSafetyEnabled(true);
testJaguar.set(testJoystick.getY());
No error message appeared on the NetBeans, but we can't get control over the Jaguar.
THANKS SO MUCH!
Unread 06-02-2012, 17:39
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
Re: Jaguar Programming with NetBeans
Have you declared testJoystick?
Are you sure the Jaguar is connected on the port 1 of the Digital Sidecar that is connected to module 1 on the cRIO?
Is the Jaguar light changing to red/green or is it always at yellow?
Unread 06-02-2012, 22:06
severhale severhale is offline
FRC #4097
severhale is an unknown quantity at this point
The fact that you're not getting any errors means that testJoystick is declared, but does it have a value? Are you saying
testJoystick = new Joystick(portNumber);
If you're not, you'd be getting a null pointer exception in the console.
Unread 07-02-2012, 17:13
FRC #2198
The joystick is declared in the beginning.
The Jaguar is for sure connected to module 1.
And the light on the Jaguar is always blinking at yellow.
Unread 07-02-2012, 17:14
FRC #2198
It is declared as testJoystick = new Joystick (1);
Is there anything else we need to do?
Unread 07-02-2012, 18:04
neal's Avatar
Neal
In the Setup tab in Driver Station, do you see your joystick in port 1?
Unread 08-02-2012, 16:23
AKA: Brad
#0190 ( Gompei and the Herd)
private testJaguar;
THANKS SO MUCH!
Is your code in a loop in the OperatorControl part of the program? If not, it will execute once and exit.
Brad
Brad Miller
Robotics Resource Center
Unread 09-02-2012, 03:15
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Try putting:
System.out.println(testJoystick.getY());
somewhere in your code.
This will print out the values of your joystick so you can see if the problem is with the jaguars or with the joystick.
Also, as people have mentioned, you need to put the code in a loop.
These are the possible loops for an IterativeRobot implementation:
RobotInit
DisabledInit
DisabledPeriodic/DisabledContinuous
AutonomousInit
AutonomousPeriodic/AutonomousContinuous
TeleopInit
TeleopPeriodic/TeleopContinuous
Now, you probably want to put it in TeleopPeriodic(). If you put it in any ----Init() method, it will run it only once. Periodic methods run at a rate that's clocked to the FPGA, and continuous methods run as fast as possible. You want to put most of your code in periodic.
Unread 09-02-2012, 11:30
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Can you post the entirety of your code? It would make diagnosing problems much easier.
Unread 09-02-2012, 16:19
Daniel Daniel is offline
Daniel Katanski
#0240
Daniel is on a distinguished road
Do not put your code in AutonomousContinuous or AutonomousPeriodic... These routines never get updates from the operator interface. You should use TeleopPeriodic this gets called only when there is a new message from the operator interface. (Been there, done that.)
Unread 14-02-2012, 20:26
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
You said the light was blinking on the jaguar, that means it is not getting the code, find electrical to check wires and make sure you have the right ports!
Off to WPI!
Go OxBE4
Unread 15-02-2012, 04:02
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
as mentioned before... if you enable the robot and the light on the jags are still blinking then that means the jag is not properly receiving communication from the digital side car... it should go solid even if your joystick didn't work or if you had no joystick at all.
A blinking light indicated bad comms. This is true for jags and victors.
I would start by making sure your cables work and plugged in correctly. Make sure you are plugged into the PWM slot and not the DIO slot for example.
Then I would look so see where you are instantiating the new jag... you should be instantiating the new jag in RobotInit, AutoInit, or Teleop Init...
Once you have a solid light when the robot is enabled then I would make sure to call the set() method in a loop like teleop period, and you might want to use joystick.getrawaxis( # ) instead of gety() if you still cant command the jags.
