Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Unread 09-02-2012, 18:22
ColonelThrtyTwo's Avatar
ColonelThrtyTwo ColonelThrtyTwo is offline
FRC #3676
ColonelThrtyTwo is an unknown quantity at this point
Re: Can't Get Compressor to Run
Originally Posted by Mark McLeod View Post
How do you have the pressure switch wired?
It should be signal & ground, the outside wires of a PWM cable, no power.
Yep
To bypass it you can short across the pressure switch terminals. The compressor should turn on then.
Doesn't seem to work. The switch seems to be closed normally (without pressure), so shorting them wouldn't do anything afaik.
Unread 09-02-2012, 18:32
It just eliminates the switch as the cause of your problems.
It is closed below ~95psi, and open at ~115psi, remaining open until it drops below 95psi again.
So it's not the switch, since it's out of the picture when you short across it's terminals.
Does the Digital Sidecar have all three power lights bright green? Some times it's a lack of proper power, other times the DIO pins could be shorted improperly.
I assume the Relay indicator on the Sidecar is not turning green either.
After that it's most probably your code.
