Go to Post (i would watch out for those jag's if i were you) - Scott Bahl [more]
Unread 09-02-2012, 00:04
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Ip Isuess.
So basically the netbook was running fine but I decide I wanted to go on the internet so I set the IPv4 settings back to auto ( I wrote down the original IP) but when I wanted to connect again to it, I replaced the IP address but it will no longer connect to the router. Since I didn't change anything on the router it must be the netbook. MY DNS is blank could that be it... or is it the subnet mask, the Default gateway is left blank is that okay?
Unread 09-02-2012, 18:27
nitneylion452's Avatar
AKA: Joe Lee
Re: Ip Isuess.
Subnet mask should be 255.0.0.0
Default gateway is 10.te.am.1
I don't think this should make a difference.
Another option is that your netbook is not set to connect to the robot's network. Go to your wireless networks and check to see if you are connected.
Hope this helps.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 09-02-2012, 18:33
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Ip Isuess.
Ip: 10.xx.yy.6
where xx.yy is your team number
example:
10.30.38.6
Subnet Mask: 255.255.255.0
Unread 11-02-2012, 18:08
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Ip Isuess.
Putting your number in the driver station fixes your IP settings
Unread 11-02-2012, 18:14
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Ip Isuess.
Only if you have the driver station set up to automatically configure your network adapters... On my driver station I manually set up my IP address for specific reasons.
