Go to Post It is hard to write code that conforms to a standard that isn't published... - AustinSchuh [more]
Unread 09-02-2012, 19:28
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Cimple Boxes
Originally Posted by midway78224 View Post
We test are 4 of our batterys around the same voltage the highest being a 13.2 and the lowest being a 12.8 and had all the same effect.
Originally Posted by slijin View Post
Measure the battery voltage under a load and see what it reads.
emphasis mine; if by "test" you mean apply a multimeter across the leads, that just gives you a nominal voltage; internal defects stemming from extended operation or other reasons could prevent the battery from effectively providing a 12v power supply, which is why I suggested testing under a load. That being said, if you are having this issue no battery which battery you use, then it's unlikely that the problem lies with the battery.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 09-02-2012, 19:37
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Re: Cimple Boxes
we ran all out motors at same time and it drop to 10v it only drop to 9v when we turned and it would stall out.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 10-02-2012, 11:17
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Re: Cimple Boxes
we had this problem too! you have to charge it longer even if it says fully charged because volt meters dont measure under load the battery wasnt fully charged. so charge them longer.
Unread 10-02-2012, 12:39
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Cimple Boxes
I highly doubt this would ever fix a problem, since I'm sure most teams (if not every single one) uses smart chargers that after reaching the battery's full charge state will drop the current output to a very small value for "trickle charging". What you are referring to is a concept called "surface charge", which Al talks about here:
http://www.chiefdelphi.com/forums/sh...47&postcount=8
Madison is most assuredly correct. Even if you find that one battery is indeed bad you should use the fantastic spreadsheet that JesseK made to help on this:
http://www.chiefdelphi.com/media/papers/2469
Since you are running 6WD, in the spreadsheet linked above consider it as a 4WD with a shortened wheel base. Make sure to find the appropriate coefficients of friction for your wheels. You did not indicate the type of wheels, just the diameter. Assuming you are using all KOP wheels the friction coefficient is about 1.
When I put in this data in this spreadsheet it shows that you are geared way too high (15 fps, wow...). It is important to go through a good design process when you are involved in this kind of competition. After putting in for the Toughbox that brings you down to 7.2 feet/second, much more tolerable and even able to rotate, how about that.
Unread 10-02-2012, 13:52
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Cimple Boxes
Keep in mind that if all wheels are identical, you theoretically can not turn if the width of the wheel base is less than the length of the wheel base. The six wheel design intends to essentially half the length by turning on the center wheels. This only works if there is more weight on the center wheels - which is why the drop in the center. To make this technique most effective, it is best to make sure the COG is over the center wheels as well. If you have too much weight on front or back it will cause more scrubbing, increase friction, increase current and make it hard to steer. The other way to reduce scrubbing is to replace front and/or back wheels with Omniwheels - replace the ones on the side with more weight.
