Go to Post "The hardest part about building the robot is figuring out what to build..." - Jeff Waegelin [more]
Unread 09-02-2012, 17:39
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Cimple Boxes
We are stalling while turning. We ran a fully charged battery that was showing 12.9v but when we turn it drop down to 9.1v. We are running 8 inch wheels and the drive is 12(gearbox) to 22 (wheel sprockets). any ideas.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 09-02-2012, 18:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Cimple Boxes
What kind of wheels are you using? Are all of them powered?
You're struggling to overcome the force of friction that's opposing your skid-style turning. To fix that, you'll need to:
A) Reduce the friction between some of your wheels and the carpet.
or
B) Shorten your wheelbase somehow
or
C) Gear your robot lower, trading speed for more torque to help overcome the friction.
At this stage, I'd recommend option A. You may have success with C as well, though. ~8.5:1 is a really fast gear ratio for 8" wheels. You might want something closer to 12:1.
--Madison--
...down at the Ozdust!
Unread 09-02-2012, 18:07
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Cimple Boxes
or
or
We had the same issue last year, and using 8inch omins in the front solved this for the most part.
Is this the 6 wheel C-Base frame?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 09-02-2012, 18:14
AKA: Rudy
FRC #5572 (Rosbots)
Re: Cimple Boxes
We are running a six wheel drive with 8 inch first wheels. All wheels are powered. We have some tough boxes that we will switch out for the cimple boxes at our next meeting.
[size="1"]
Unread 09-02-2012, 18:15
Mk.32's Avatar
AKA: Mark
Re: Cimple Boxes
Is the center wheeled lowered at least a 1/8th of an inch?
And tough boxes will help, a lot.
Unread 09-02-2012, 18:36
AKA: Rudy
FRC #5572 (Rosbots)
Re: Cimple Boxes
Yes, they are lowered by the hole with the kit chassis which i believe is an 1/8th of a inch
[size="1"]
Unread 09-02-2012, 18:39
nitneylion452's Avatar
AKA: Joe Lee
Re: Cimple Boxes
Are all the wheels rubber or are there some plastic ones?
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 09-02-2012, 18:42
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Cimple Boxes
This is also indicative of a battery problem. Measure the battery voltage under a load and see what it reads.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 09-02-2012, 18:55
AKA: Rudy
FRC #5572 (Rosbots)
Re: Cimple Boxes
We are running 8 inch first wheels so they are rubber.
We test are 4 of our batterys around the same voltage the highest being a 13.2 and the lowest being a 12.8 and had all the same effect.
[size="1"]
Unread 09-02-2012, 19:27
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
Re: Cimple Boxes
not necessarily the internal Resistance of the battery is pretty high in 2009 our bot operated at 8.5 volts dropping to 7.5 when we started shooting on a fully charged battery
if you have a high enough load and enough motors going the voltage can and will drop below 7 volts on a good battery.
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 09-02-2012, 19:28
slijin's Avatar
Pockets
AKA: Samuel Lijin
Re: Cimple Boxes
emphasis mine; if by "test" you mean apply a multimeter across the leads, that just gives you a nominal voltage; internal defects stemming from extended operation or other reasons could prevent the battery from effectively providing a 12v power supply, which is why I suggested testing under a load. That being said, if you are having this issue no battery which battery you use, then it's unlikely that the problem lies with the battery.
Unread 09-02-2012, 19:37
AKA: Rudy
FRC #5572 (Rosbots)
Re: Cimple Boxes
we ran all out motors at same time and it drop to 10v it only drop to 9v when we turned and it would stall out.
[size="1"]
Unread 10-02-2012, 11:17
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Re: Cimple Boxes
we had this problem too! you have to charge it longer even if it says fully charged because volt meters dont measure under load the battery wasnt fully charged. so charge them longer.
Unread 10-02-2012, 12:39
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Cimple Boxes
I highly doubt this would ever fix a problem, since I'm sure most teams (if not every single one) uses smart chargers that after reaching the battery's full charge state will drop the current output to a very small value for "trickle charging". What you are referring to is a concept called "surface charge", which Al talks about here:
http://www.chiefdelphi.com/forums/sh...47&postcount=8
Madison is most assuredly correct. Even if you find that one battery is indeed bad you should use the fantastic spreadsheet that JesseK made to help on this:
http://www.chiefdelphi.com/media/papers/2469
Since you are running 6WD, in the spreadsheet linked above consider it as a 4WD with a shortened wheel base. Make sure to find the appropriate coefficients of friction for your wheels. You did not indicate the type of wheels, just the diameter. Assuming you are using all KOP wheels the friction coefficient is about 1.
When I put in this data in this spreadsheet it shows that you are geared way too high (15 fps, wow...). It is important to go through a good design process when you are involved in this kind of competition. After putting in for the Toughbox that brings you down to 7.2 feet/second, much more tolerable and even able to rotate, how about that.
Unread 10-02-2012, 13:48
AKA: Joe Lee
Re: Cimple Boxes
Sorry, I hadn't noted the team number. In 2010, the KOP came with some plastic wheels in addition to the rubber ones. Try swapping your front and back 2 (or your middle 2 if you'd like) with some plastic wheels. The decrease in friction while turning will make the robot turn much more smoothly and might solve your stalling issue.
AM sells the plastic wheels for $12.00 each.
http://www.andymark.com/product-p/am-0494.htm
Joe
