Go to Post When I'm asked the question, "What is the most important computer language to learn to prepare me for a programming career?"; my answer is, "Your second one." - Greg McKaskle [more]
Unread 09-02-2012, 18:32
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Jags will not calibrate
New weird issue...
Configuration:
4 black jags wired to CIM motors
Running Mecanums on the Nanos (kinda rhymish )
Using PWMs to Digital Sidecars
Scenario:
Tried to calibrate jags but two would not calibrate (on opposing corners of the bot).
After multiple attempts to calibrate:
Changed out PWMs for new ones....still didn't calibrate
Then
Changed out jags for two good ones that had been previously calibrated...still didn't calibrate
Ideas? Would like to figure out the problem because it is kind of tweaking our drivers a little bit (I suggested changing the power wiring and have been told it is a 'non-factor' their latest new terminology...)
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 09-02-2012, 18:38
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Jags will not calibrate
Originally Posted by rsegrest View Post
New weird issue...
Configuration:
Scenario:
Then
Try reversing the PWM ports on the DSC (that is, switch the PWMs to the non-functional Jaguars over to the PWM outs of the ones that do work). If this works, then those specific DSC output pins are bad.
What exactly did you mean by "didn't calibrate"? For FRC, Jaguars' default factory calibration is acceptable for drivetrain use.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 09-02-2012, 19:38
rsegrest's Avatar
Will try this next and let you know...
~ Unknown
Last edited by rsegrest : 09-02-2012 at 19:39. Reason: re-read problem answer and realized I am a dufus...
