Go to Post FIRST isn't a competition. It's a learning experience. Share the knowledge, and you'll learn more because there's bound to be someone who sees something about your project that even your own team didn't realize it can do. - CalTran [more]
Unread 09-02-2012, 19:54
patcc2 patcc2 is offline
FRC #1980 (The Brigade)
patcc2 is an unknown quantity at this point
Running Individual Motor Problems
Hi,
Personally I have had individual motors running before but for some reason the sophomores I put on this task are having serious trouble. I did a quick check on the wiring and the code and it all seemed to check out. He ran the motor in some tank drive code and it worked fine but the individual motor would not run.
I'm wondering if anyone has been experiencing a similar problem and if so how did they fix it?
Unread 09-02-2012, 20:35
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
Re: Running Individual Motor Problems
What are you using to control the motor? A spike? A jaguar? A victor?
For now I'll assume jags, because you mentioned tank drive code...
Is it just one motor out of a large group of them in a drive train?
Unread 09-02-2012, 21:49
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
So it runs but it doesn't run?
Some more details would be nice. What speed controller are you using? PWM or CAN? What's the difference between tank drive code & working fine and individual & not working?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
