Go to Post So my mom gave up most of the house to robotics.... - ElfMaster [more]
Unread 14-01-2012, 16:48
pureFloat pureFloat is offline
AKA: Moby
FRC #3506 (Yeti)
pureFloat is an unknown quantity at this point
Java to Crio Downloading Issues
My team is using Java to program our robot, and we want to put a simple project we created onto the Crio. We have imaged our Crio and have set the laptop's IP address. When loading the code, Netbeans gives us this message:
Target IP: 10.35.6.2
Network interfaces on host:
    Realtek PCI FE Family Controller: address: 10.35.6.7 netmask: 255.255.255.0 <--- on robot's subnet
Connection FTP @10.35.6.2
And then it stops. It doesn't give an error or anything. Does anyone have any idea what's going on?
Unread 14-01-2012, 17:02
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
The computer is unable to connect to the robot. There is likely an iphone address set incorrectly somewhere.
Unread 14-01-2012, 17:27
AKA: Moby
FRC #3506 (Yeti)
Re: Java to Crio Downloading Issues
Ok, we got it. It turns out I overlooked firewall. Stupid firewall. However, now we're running into a new issue. Netbeans is now giving us this message:
Waiting to connect to OTA command server of 10.35.6.2:8001 for past 43s
Waiting to connect to OTA command server of 10.35.6.2:8001 for past 44s
Waiting to connect to OTA command server of 10.35.6.2:8001 for past 45s
It keeps going on. My friend says it should work in 7 seconds, but now it's at around 700. Does anyone know what this means and how we can fix it? Thanks to anyone who helps.
Unread 14-01-2012, 17:29
Captain
You need to restart your crio and download once more. This happens once after imaging the crio.
Unread 14-01-2012, 17:48
AKA: Moby
FRC #3506 (Yeti)
Cool! That works. Now we just need to get the actual code working
Unread 14-01-2012, 18:11
Captain
Glad to hear it works. You should try some of the examples.
Unread 16-01-2012, 17:30
leeboy1312 leeboy1312 is offline
FRC #4021
leeboy1312 is an unknown quantity at this point
We are having a similiar problem when we try to deploy the code onto the CRio the program stops without a build error at
[cRIO] Default disabled() method running, consider providing your own
[cRIO] task 0x25c7a58 (System Web Services Load Thread) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x2869f70 (mDNS resolve) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x2bff0d0 (mDNS resolve) deleted: errno=0 (0) status=0 (0)
I have tried almost everything i can think of so any help would be strongly appreciated.
Thanks,
F.I.R.S.T. Team #4021
Unread 16-01-2012, 18:09
Captain
That is displayed whenever you finish deploying the code.
Unread 08-02-2012, 22:41
matthysen2 matthysen2 is offline
FRC #3735
matthysen2 will become famous soon enoughmatthysen2 will become famous soon enough
I have had this same problem aswell. When you say restart do you mean pressing the button on the or cutting the power off and then turning it back on? And should this be done while the code is trying to run?
Unread 08-02-2012, 23:16
Captain
You will need to power cycle the entire robot. You do not want to power cycle the robot while it is running the code.
Unread 09-02-2012, 03:08
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
It's a known bug since last year.
SOP for flashing/updating the crio:
1. Flash it
2. Upload code
3. Reboot the crio
4. Pretend nothing happened and upload code
5. Success.
Unread 09-02-2012, 08:25
touchdownjesus4's Avatar
touchdownjesus4 touchdownjesus4 is offline
AKA: Tyler Vonderhaar
FRC #4028 (Eagle Robotics)
touchdownjesus4 is on a distinguished road
Thanks,
This same thing happens when I deploy code to our cRIO. It gets to the mDNS resolve and hangs. I've found that if you just stop the process it deploys the code correctly, it just seems to get hung up after its finished deploying for some reason. It says that there is robot code when we switch to the driver station and any changes we make work even though it hangs.
2012 Boilermaker Regional Champions (With 1756 & 1501)
Team Captain, Programmer, Lead Driver
Unread 09-02-2012, 10:57
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: Apparent "hangs" in code deploy to cRIO...
The deploy process is not supposed to "finish". It stays connected to your robot in order to display any output that your robot or the cRIO prints out.
This message is printed by WPILibJ if you haven't overridden the disabled() method (which isn't a requirement by the way):
If you see that message, then it's very likely that your robot code is running fine.
This message is printed by the cRIO for some reason. I think it is an ordinary status message though, not any real problem:
For your own sanity and/or peace of mind, you might want to print a message at the beginning and end of your disabled(), autonomous() and operatorControl() methods - something like "entering autonomous mode", "exiting autonomous mode", etc.
Unread 09-02-2012, 19:57
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
hello, we are having the same problem as you, we dont have any firewall running that we know of and have had 3 people check it. Can you tell us what you did so we can try to fix ours?
we try to send code but get the same error that says connection has timed out and we can't figure out why....
heres what we get...
Target IP: 10.0.0.2
Intel(R) 82567LM Gigabit Network Connection: address: 10.17.43.5 netmask: 255.0.0.0 <--- on robot's subnet
Intel(R) WiFi Link 5100 AGN: address: 10.10.12.154 netmask: 255.255.255.254
Connecting FTP @10.0.0.
we are thinking we need to change the target ip address to the 10.17.43.5 but are unsure of how to do this and are trying to figure out if this is the real reason for our problem...
Team 1743
Head Programmer
Unread 10-02-2012, 00:49
TravSatEE's Avatar
TravSatEE TravSatEE is offline
Spacecraft Engineer and more
FRC #2035 (Robo Rockin' Bots)
TravSatEE is infamous around these partsTravSatEE is infamous around these parts
There is a netbeans configuration option to change, in the menu:
Tools -> Options -> Miscellaneous -> FRC Configuration
Change your team number.
This step is missing from [1]. Their section on Netbeans is a little sparse and references an older version (6.7). No one took credit as author on that document to suggest this change.
[1] http://www.usfirst.org/sites/default...20System_2.pdf
