Go to Post I believe the only cure... is more cowbell? :D - The Megan 2207 [more]
Unread 09-02-2012, 19:38
RahatAhmed RahatAhmed is offline
FRC #4300 (The Lion Kings)
RahatAhmed is an unknown quantity at this point
Wiring Ring Light?
We purchased a couple of these ring lights: http://www.superbrightleds.com/cgi-b...specs%2FAE.htm
Unfortunately, the wires coming out of these are ridiculously small. We had to use a knife to strip them, and even then we had no way of wiring them into the PDB. We tried to crimp them into inline connectors along with some higher gauge wires to go directly into the PDB. However, that did not work, because the small wire was too fragile to crimp. We tried twisting them to the higher gauge wire directly and they would not turn on. How have your teams wired them?
Unread 09-02-2012, 20:02
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
Re: Wiring Ring Light?
We carefully stripped them and inserted them into the PD Board. If you strip it the right length and put it it right, it should stay in like any other wire. Another idea that I just came up with is to flatten a larger stranded wire, melt some solder onto it, and place the small wire into it, then cover with electrical tape.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 09-02-2012, 20:13
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
We actually pulled the wires off the light and soldered on a PWM cable . Works much better in the P...
"No, you can't use the Kinect to do pelvic thrusts."
Unread 09-02-2012, 20:31
Djinn74's Avatar
Djinn74 Djinn74 is offline
C++ Ninja in training
AKA: Henry Braeske
FRC #3397 (Robolions)
Djinn74 is an unknown quantity at this point
Melt the solder holding the small wires to the ring light with a soldering iron, take them out then use the existing solder to attach larger wires. It worked for us.
"Its totally going to be a water game!!"
"Bet you $10 that it isn't.
"Yeah... not making that bet."
Unread 09-02-2012, 20:33
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
That's not a bad idea... Might have to try it myself... For now though, we used some of those terminal blocks that we seem to have ever so many of to connect the light to some heavier wire. (which then connected to the PD board)
Unread 09-02-2012, 20:55
CRLS97 CRLS97 is offline
FRC #0097
CRLS97 is an unknown quantity at this point
WARNING-ish.
I don't know if this has happened to any other team, but our ring light shorted somewhere along the skinny wires they shipped with and there was a small electrical fire (while it was on our robot). Although we had it soldered to a thicker cable (was heavily covered up by electrical tape ) that went to the PD board, we're sure it happened somewhere along the skinny cable because the shorting happened somewhere along the upper half of the wire (which literally melted away).
We got rid of all the wires and soldered 12 gauge wire directly the ring itself and power comes from the PD board. The light glitched a bit at first (one of the LED's stopped working) but came back to life the following day.
Whatever you do, make sure the wires that connect to the ring light don't touch each other!
-btw one of our mentors thought this was weird because a breaker should trip when something shorts, but that didn't happen. maybe because our shorting issue went away after the wire melted? any answers to this o.O?-
Unread 09-02-2012, 21:00
The wire on the ring lights is much too small to be adequately protected by a 20A breaker. It likely burned through and eliminated the short before the breaker could trip.
Unread 09-02-2012, 21:39
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
You should never need a knife to strip wires. The link you give doesn't take specs for the wire gauge, but I doubt it's any more than 30AWG. You should look into getting some appropriately sized wire strippers. I personally prefer these, but there are plenty of good strippers out there. The only advice I'll offer on that point is to not get an automatic stripper.
With regards to CRL's post, it is very easy for thin wires to catch fire without tripping the breaker, simply because the current draw won't trip it (as has already been pointed out). It's hard to believe that the manufacturer would make such a mistake, but nonetheless, if you do resolder the wires (which is generally simpler and neater than soldering the existing wires to thicker ones), check for shorts before you power it, or power it away from the robot to make sure there are no shorts.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 09-02-2012, 21:40
jp1247's Avatar
FRC #1247 (ROK BOT)
Perhaps current was just flowing through one of the SMD resistors. 20 amps through a resistor makes some kinda heat.
Unread 09-02-2012, 21:45
slijin's Avatar
Pockets
AKA: Samuel Lijin
A resistor would limit current and be more likely to prevent a fire than induce one. Just because the fuse on the circuit is for 20A doesn't mean the circuit will draw 20A.
Unread 10-02-2012, 03:53
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
The insulation on the ring lights is so soft we stripped them with a fingernail!! I would NOT solder them as that insulation will melt quickly. We stripped them, folded the bare wire over itself so it is thicker, crimped it in a butt splice, crimped the other end to some 22AWG cable and ran it to the M+ and M- terminals of a spike so we can turn it on and off. The GND and 12V terminals of the spike go to the PD board.
HTH
Unread 10-02-2012, 15:45
For testing, I connected the ring light's thin wires to 20 gauge conductors from a Spike using a short section of the green terminal strip from the Kit of Parts.
Today, as the final wire routing is set on the robot, I plan to replace the existing wires entirely and use a four-conductor cable to bring power to both the LEDs and the camera itself.
What I'd really like to do is to get my hands on a supply of Ethernet jacks and mess around with tunneling power through a single patch cable from the electronics box to the camera, but that's not going to happen this year.
Unread 10-02-2012, 22:58
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You mean Power over Ethernet? There are hundreds of off the shelf devices that do just that.
Unread 11-02-2012, 01:27
Originally Posted by cgmv123 View Post
No, that's not what I mean. I don't want to do anything so expensive and heavy and intrinsically safe as POE. I just want to employ the unused four wires in an 8-wire ethernet patch cable to carry 5 volts to power the camera and a switched 12 volt circuit to power the ring of LEDs.
Unread 11-02-2012, 02:19
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
We can't do PoE, the bridge FIRST specifies is not PoE.
