Go to Post The engineer mentors ARE part of the team, equals with the students in every aspect - KenWittlief [more]
Unread 09-02-2012, 21:18
2869Robotics 2869Robotics is offline
FRC #2869
2869Robotics is an unknown quantity at this point
Gyro
How would I wire up the gyro? Where would I connect the gyro to? Thanks in advance.
Unread 09-02-2012, 21:25
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Gyro
Hook the gyro to an analog input channel. 3 pins: +5 to +5, Gnd to Gnd and ANA to signal.
Unread 09-02-2012, 21:40
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Gyro
If you're using the KOP gyro, remember to use the RATE pins, not the TEMP ones.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
