Go to Post It's not just well and good that students are being inspired, it's the whole dang point. - James1902 [more]
Unread 02-09-2012, 10:04 PM
Derek012's Avatar
Derek012 Derek012 is offline
I miss my frisbees
FRC #4564 (Orange Chaos)
Derek012 is on a distinguished road
Re: Gyro Code
The wpilibj offers a class on their API http://www.wbrobotics.com/javadoc/ed...libj/Gyro.html
but you would need to create the Gyro object then specify which analog port on the cRio you are using,
Gyro gyr = new Gyro(aPort);
Then in the method your choosing for your implementation you would call the angle using, gyr.getAngle();
This method isn't exactly what it seems though because a gyro calculates its angles by rate you may need to set your sensitivity different depending on your gyroscope using gyr.setSensitivity(int volt/degree/sec);
Also for those times were you need to reset to zero there is a reset() that you can use.
