Go to Post Breath in. Breath out. We still love you - its ok! :^) - KenWittlief [more]
Unread 09-02-2012, 20:15
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Rookie Team 3992 Launcher!
100% consistent!
We're going to change speed of the wheel and angle, to get into the top hoop.
Stay tuned!
http://youtu.be/ULOqQCh59vA
Feedback and comments appreciated!
Unread 09-02-2012, 20:30
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
Re: Rookie Team 3992 Launcher!
Looks really good... Although I am curious... Don't you get issues with the ball feed using only the one belt? Even with the 2 pipes?
Last edited by aeniug2 : 09-02-2012 at 20:31. Reason: took a second look at the video...
Unread 09-02-2012, 20:40
ksafin's Avatar
AKA: Kirill Safin
Not so far;
We've tested using 3 balls in the belt at once, and everything worked fine.
Feeding is pretty consistent.
Unread 09-02-2012, 20:52
aeniug2's Avatar
AKA: Joseph
Originally Posted by ksafin View Post
Not so far;
Sweet... Ill keep that in mind when we assemble our launcher tomorrow... Thanks for posting the video btw... Without videos of other people's launchers I don't think our team would have ever started on ours...
(they don't like how everyone else is ahead of us, lol)
Unread 09-02-2012, 21:38
pfreivald's Avatar
AKA: Patrick Freivald
That looks really great, guys and gals! The mechanical consistency is impressive. (We also have a belts-and-two-rails system that is very consistent, though we use more belts... Something to consider is when you get hit by other robots, will the balls pop out?)
If you can aim, you'll have a very competitive bot!
(Yay, rookies!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 09-02-2012, 22:17
ksafin's Avatar
AKA: Kirill Safin
(Yay, rookies!)
Thanks!
We'll definitely look into more belts. As it is right now, I think the biggest problem will be that, you can put a ball in directly centered, or you can put a ball in so that the belt is slightly on the left or right of the "equator" of the ball. So I'm wondering how we can make sure each ball goes in exactly centered.
Similarly we're finding the problem with consistency to be affected by how used the balls have been. We're looking toward the "window" we have where the slightly newer balls rebound off the backboard, and the slightly older balls go straight into the hoop. If we can get it to aim within this window, we think we should be set..
We'll order belts today
Unread 09-02-2012, 22:25
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
What is the top part of it? Is there a hood that follows a radius from the wheels or just a bar
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 09-02-2012, 22:29
pfreivald's Avatar
It's easy to forget in the excitement of your first build that your robot is likely to get the living crapola rammed out of it during games. We ram ours into walls, flip it over onto its sides, tug on cables... I suggest that, as soon as you have it working, you do the same -- and then fix whatever no longer works, and then do it again, and again, and again, until 2-5 times in a row there's nothing to fix.
Consider some kind of funneling system from your ball pickup, if you haven't already. The dual rails help a great deal, and one belt might be sufficient -- three-point centering is older than Newton! (The scientist and the field).
Yup. That's true with everyone. Your 'sweet spot' technique is a good one, to be sure!
We made our own from surgical tubing, 12 gauge wire, and superglue.
Team 1551
I write books, too!
Unread 09-02-2012, 22:42
ksafin's Avatar
AKA: Kirill Safin
It's copper pipe that we bent around the radius of the wheel.
Will do; we just want it to work first though
[Consider some kind of funneling system from your ball pickup, if you haven't already. The dual rails help a great deal, and one belt might be sufficient -- three-point centering is older than Newton! (The scientist and the field).
I see. I'm thinking the bottom of the conveyor can start open, then we can put two angled sheets of lexan that will gradually compress the ball to be the same each time.
Thanks!
Impressive!
Unread 09-02-2012, 23:05
nitneylion452's Avatar
AKA: Joe Lee
I think you're showing me the same shot over and over again. You guys have a really good video editing team! You can't even tell!
Seriously though, great work! That looks fantastic!
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 09-02-2012, 23:31
ksafin's Avatar
AKA: Kirill Safin
Haha thanks so much!
Very encouraging words
Unread 10-02-2012, 03:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
When you get on the field, the conditions end up being pretty much nothing like your test space. It's the unfortunate reality of FIRST (and 99% of engineering in general). You guys have definitely done some impressive work for a rookie team, but there's a couple issues that could crop up once you set it on the field of competition.
Your feeding belt takes an awfully long time in FIRST scale. Five seconds doesn't seem that long in the real world, but in a 2:00 match having to wait five seconds for balls to traverse the final two foot span of your robot isn't a good idea. Especially considering that there's five other robots on the field complicating things, three of them actively working against you. You may want to attempt to speed that process up.
It looks like you're using a Fisher-Price motor into the stock gearbox, directly feeding a rotating barrel (PVC?). You could increase the diameter of the barrel to get faster belt speed, or you could gear up your current barrel after the gearbox. This is assuming that you are not currently reducing the power to your motor via software.
As mentioned and you guys realize, centering the ball can be a big deal. Fortunately, it may also serve to help protect your balls from being dislodged or repositioned during a match. Try to prevent as much unwanted motion of your payload (the balls) as possible. But at the same time, avoid causing any jams in the system. Make sure your centering and protection devices don't cause balls to get stuck.
Aiming from a distance is difficult. Especially considering your drivers are another 40+ feet from your robot when you're attempting to shoot. You might want to consider features to help your robot aim, and perhaps from a closer distance (such as actually in contact with the fender). The holy grail in this situation is camera tracking and rangefinding of the targets, but very few rookie teams have the time and experience to code, test, and debug those type of systems.
Good luck!
Unread 10-02-2012, 06:49
pfreivald's Avatar
The same is true with some of us veteran teams!
Team 1551
I write books, too!
Unread 10-02-2012, 13:46
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
I like the design; we are doing something similar. It appears that there is only a sprocket on the belt at the top and it is just wrapped around a pvc roller at the bottom. Is this accurate, and if so, how well does this work. Does the bet transfer enough torque to the roller, or is that not necessary in your design?
Are you suggesting that 3pt centering would be better than using 5 points of contact (belts + 4 pieces of aluminum in a similar set up to this)? if we had 2 belts, should we put them closer toegether to keep the contact close to one point or spread them out (2-4") apart so that the ball isn't affected as much by being slightly misaligned?
Unread 10-02-2012, 15:03
pfreivald's Avatar
Not to sound glib, but this is something you'd probably have to experiment with yourself. This is what we went with: http://www.youtube.com/watch?v=ZTQ-dU96c2A
Team 1551
I write books, too!
