Go to Post I still believe that if we are legitimately trying to make FRC be recognized as a real sport, then the GDC must treat it like one. - Jim Zondag [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 07-02-2012, 23:08
Tub Tubs Tub Tubs is offline
FRC #3049
Tub Tubs is an unknown quantity at this point
Deployment error
I noticed on the newest version of labview that whenever i deploy a different program, then i would get an error. but when i reimage the C-Rio, i can deploy said project without error. is there any fix for this or anything else i can do
Unread 07-02-2012, 23:26
Re: Deployment error
It's not an error, but a warning that we are replacing existing code.
That's okay, we want to replace the code.
It happened with the last version of LabVIEW we used, too.
It's sort of the LabVIEW version of "Are you sure?"
Unread 09-02-2012, 11:58
FRC #3049
its not that, i know that this is the case, but the robot wont work at all if i deploy anyway
Unread 10-02-2012, 00:15
If you're using the "Deploy" command, you're not ensuring that the newly installed program will actually run when the cRIO starts up. Instead, you should use the "Run as startup" command.
You are doing a "Build" before you try to load the code onto the cRIO, right?
Unread 10-02-2012, 22:11
FRC #3049
yes
