Go to Post unless your team is incredibly beastly, completely ignore the words "cool factor". Coolness does not outweigh functionality. - Sam N. [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 10-02-2012, 00:41
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Re: no response from jags in CAN
How are you connecting the cRIO to the jaguars?
If you are using the serial port, make sure that you re-image the cRIO with the appropriate Serial CAN Jaguar option. Also make sure that the jaguar initializers in the Begin.vi, are set-up for CAN Jaguar. Verify that the correct CAN addresses are specified.
If that doesn't help, then load up the CAN Jaguar example code, and see if you can make that work.
