Go to Post This isn't a golden ticket - it's a golden opportunity. It's up to you to earn it. - Jessica Boucher [more]
Unread 10-02-2012, 01:34
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Re: Java to Crio Downloading Issues
Open up your netbeans settings, click the miscellaneous tab, click the FRC Java tab, and set your team number in there.
Unread 10-02-2012, 11:20
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
thanks, we have done that and will test it in a few hours. I will respond back if it works.
when we set it in netbeans we got set remote address to (10.17.43.2) which i am going to assume is correct?
also...
using command prompt and the ipconfig command,
we have the:
IPv4 - 10.10.12.154
subnet - 255.255.0.0
default gateway 10.10.0.1
we are team 1743 so i know it should read (10.17.43.6) there...
but i am unaware of what it should correctly read.... Can someone post up an accurate example of exactly how it should be?
Team 1743
Head Programmer
Unread 10-02-2012, 15:35
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
also...
we have the:
IPv4 - 10.10.12.154
What is your exact setup? If you use the wireless router on the robot as an access point, you don't need to configure the default gateway on your computer. Disable DHCP on the router and manually change your address to 10.17.43.x, where x is an integer 0~255 and not 1, 2, 4 or 6, or 11 (to be safe).
Unread 10-02-2012, 15:37
FRC #1743
so we fixed the ip address issue (thanks for the help)
now we got another issue (lol)
we are getting an error where it says looking for frc_2012_v43.zip but got frc_2011_v28.zip
we tried looking for where it is calling for this file path but we couldn't find it... our netbeans is updated to the fullest and has all of the plug-ins installed...
Team 1743
Head Programmer
Unread 10-02-2012, 15:48
Programming
Two things you should try:
1. Update your cRio flashing utility. The 2012 version has some major changes done to it.
2. Uninstall, reinstall the plugins in netbeans. Those plugins *should* contain the cRio image files.
Unread 10-02-2012, 19:40
FRC #1743
ok the flash utility is just the cRio imager correct?
our netbeans is currently up to date with all of 2012's updates for frc.
will keep you guys informed..
we are using wired connection right now and trying to get that set-up before wireless...
Team 1743
Head Programmer
