Go to Post YES!!!!!! I read this and jumped! This is awesome and amazing! Thank you so much Dean Kamen and FIRST!!! YOU ARE AMAZING! - torihoelscher [more]
Unread 10-02-2012, 09:13
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Driving long?
FIRST Team 1296 went long so going over the bump will be easier and mounting a ramp lower device seemed easier (given the geometry of our gatherer). Madison is right about the small aperture gatherer mechanisms on long chassis, thus ours gathers from all 4 sides.
Our mecanum drive alignment and software seems really good this year and we can spin in place once on the bridge in a couple of seconds. But is it worth it to try? I agree that 3 (traditional) robot balancing is problematic w/o time to practice the maneuver - hopefully we make it far enough for it to be feasible.
Unread 10-02-2012, 09:17
Andrew Lawrence
Posts: n/a
Re: Driving long?
Or use 2 long robots, one wide robot. 256 is going wide this year for a few reasons, mainly because of our awesome offense, and ability to traverse the field without tipping over.
Most of all, I want to see the wide:long ratio of robots on the field vs. the wide:long ratio of robots who make it to the championships.
Unread 10-02-2012, 09:24
Greg Leighton's Avatar
Greg Leighton Greg Leighton is offline
FRC #2337 (EngiNERDs)
Greg Leighton is an unknown quantity at this point
Re: Driving long?
I like a long bot for greater field mobility which in my mind means moving over the barrier quickly with little risk of getting stuck or tipping. Like most I believe there are designs that will allow you to collect balls quickly as a long bot, so that shouldn't be too much of a disadvantage. As for the bridge balancing, I think it is far to difficult to assume you will be able to balance the bridge with 3 long bots, I think teams will design for this problem.
Originally Posted by Joe Schornak View Post
I forsee on problems in getting three long robots on the bridge, as long as you designate one team to balance and the other two teams to hold very still.
EDIT: I assume you meant "no problems"
Originally Posted by Ninja_Bait View Post
Long bots with a low, centered CoG should still be able to balance three at a time, if the end robots hang off their front wheels.
With 3 true long bots (44 " long with bumpers) you have either two robots halfway off the bridge or an entire robot not taking up and bridge space at all. So in the scenario where you have two robots hanging of either end of the bridge, assuming they have a centered CG the robot in the middle cant move at all without tipping the bridge. Sounds a tad bit difficult to pull something like this off, unless you have designed your robot to do this and have had practice doing it. But this would be my last resort to bridge balancing, I would try and find another way for a long bot to accommodate bridge balancing like others have mentioned.
Good is the enemy of Great
Unread 10-02-2012, 09:27
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Re: Driving long?
Agreed - perhaps an automagical (eg s/w assisted) maneuver that enters the ramp in a long orientation but pivots as it balances - hmmm
Unread 11-02-2012, 13:41
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Driving long?
[/i]For all intents and purposes, our foot print is ~32" x 27.5"
Wow, came to the same exact size! Nice.
Unread 11-02-2012, 15:58
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Driving long?
We chose to make our robot long because Typically wide robots have issues with tipping. Because the motors do not exert force in the short direction, there is less ability for the robot to get put in a situation where it could tip. We also like the drive-ability gains for a long robot, the turns feel more responsive and quick because the wheels are closer to the middle of the robot.
