Go to Post [this is rapidly turning into a 'how many engineers does it take....' contest :^) ] - KenWittlief [more]
Unread 10-02-2012, 07:47
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Vision
I found this picture earlier and was wondering how to the camera to see the target this way
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 10-02-2012, 08:49
Re: Vision
Personally I would load it up in Vision Assistant, read the 2012 vision white paper and try out vision example code.
Specifically, if you launch the NI Vision Assistant, the first screen will have a button to Open images.
Once you have images loaded and they are shown in the big document area and you are Processing Images, click on the second button on the left center, the rainbow or color image processing button. Third on the list is a color threshold function. Choose it and adjust the sliders to mask (in red) the green parts of the image. You can do this in RGB, but it may be more precise to do it in HSL color space. If you are finding it difficult, draw a rectangle on the image that selects what the histograms display. This will give you a better idea what to set the sliders to. I attached a screenshot of this step to show the results you can achieve -- though due to the distance or light brightness, your colors are a bit dim, but workable.
From there, you have an idea of the color of your reflected target and you can use the white paper or examples to get you started.
Greg McKaskle
Name:	Screen Shot 2012-02-10 at 7.46.32 AM.png
Unread 10-02-2012, 10:05
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Vision
I also found the Rectangular Target Process example project in Labview helpful beyond belief!
Especially when you figure out you can click the target with your mouse and the Hue, Saturation, and Luminous values are set to perfect levels.
Kudos to the Labview folks at NI
The views expressed are mine and should not be construed to represent the views of anyone else.
