Go to Post now now, there is no such thing as reading the manual too much. I read it every night just before I go to bed. - 663.keith [more]
Unread 09-02-2012, 23:24
oswaldonfire's Avatar
oswaldonfire oswaldonfire is offline
Chris Marion
FRC #3142 (Aperture)
oswaldonfire is an unknown quantity at this point
Team 3142: Week 5 preview
Here is our robot as of today (2/9). We still have a ton of work to do, but things are beginning to come together! And yes, the black box has a Kinect inside..
Unread 09-02-2012, 23:25
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Team 3142: Week 5 preview
Wow this is close to how we have ours
But still not the same Great job!!
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 10-02-2012, 01:55
Joshuamunson Joshuamunson is offline
FRC #2996
Joshuamunson is an unknown quantity at this point
Does the kinect on the robot actually work?
and if so what role does it play?
Unread 10-02-2012, 05:08
TEAMROCK2000's Avatar
TEAMROCK2000 TEAMROCK2000 is offline
FRC #2000
TEAMROCK2000 is on a distinguished road
like josh was saying how does the kinect actually work on the robot.
and if u will how did u get it to work?
Unread 10-02-2012, 12:37
Chris Marion
Yep, the Kinect works - if you look closely, you can see how we put wax paper over the infrared laser projector, effectively blurring the light into a homogenous field and taking advantage of the kinect's infrared camera. When coupled with the retroreflective tape on the targets, it gives us a perfect tracking system completely immune to any changes visible light. The kinect is connected to an onboard computer, which does a huge amount of image processing to send a distance value (accurate to the inch) and information on how to move the turret (preliminary testing shows <1 degree accuracy) to the cRio.
In addition to running the Kinect, the onboard computer processes a feed from a second webcam which is pointed down at the field in front of the robot (not attached in this picture) and sends an augmented-reality video feed back to the driver station, highlighting the closest ball in green (or any other color) and overlaying information to help the driver line the robot up with the ball to pick it up.
Unread 10-02-2012, 12:54
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Oh my- how does your team have enough time for this!?! Our 5 programmers (including me) have barely gotten tracking (of the backboard) working! Great job!
And what did you use for an onboard computer?
Unread 10-02-2012, 13:12
Chris Marion
We have a mini-ITX computer running onboard; it has an Atom dual-core 1.8GHz processor, 2GB RAM, a 4GB SSD, and power regulating and supply equipment to allow it to run on anywhere from 6-34vDC (this circuitry also powers the Kinect). We're all in love with it - it's small, around six inches square, and draws maybe 30 watts and gets slightly warm while doing all its image processing.
Right now we're running into framerate issues while processing both feeds - getting only around 6fps from the Kinect and 12 at best from the other camera.. although I attribute this to the fact that we like our nice high resolutions too much - today we'll try moving down from 640x480 and we should see a huge gain in performance. Although the smaller the resolution from the Kinect, the less resolution our distance readings will have. Right now we have a reliable resolution of around 2-3 inches, which is acceptable.
I should also note that we're running the excellent RoboRealm software on the computer to do our vision processing - it's an amazingly powerful, GUI-based machine vision platform, and RoboRealm is giving free copies to any FIRST team who is interested (it's normally $50) - if nothing else, your team should grab a copy to play around with in the off-season.
I've found that it's a great tool for teaching the basics of machine vision, and its easy enough to learn the basics to get students who otherwise wouldn't step foot near C++ excited about programming and computers. I worked with two freshmen on our team to develop the Kinect targeting software, and both had no previous experience in programming. There is also plenty of room for the experienced programmer - RoboRealm has a full-featured API, built-in HTTP and FTP servers, and you can write custom image processing modules and plugins in C, Python, or Visual Basic. Check it out - http://www.roborealm.com/
Unread 10-02-2012, 13:49
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
WOW. thats awesome. Anyway we could get a writeup of this after season?
Unread 10-02-2012, 13:57
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Holy!!! How much does that BEAST way?!
Unread 10-02-2012, 20:17
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
looks great except for the weight distibution. your cg is probably going to be a foot off the ground :/
cole?
Unread 10-02-2012, 23:28
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
I'm also very interested as many probably about how you implemented kinect well enough to be put on your robot! :O. I give props to your programmer, he's got some real talent if he could do that.
Unread 11-02-2012, 19:15
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Our programmers have been working on it as well--we use a little linux comptuer called a Beagle Board. What are you guys using?
Unread 11-02-2012, 19:59
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Impressive-looking robot!
Have you calculated your center of gravity? It does look rather top-heavy, just judging from the picture.
Good luck!
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 12-02-2012, 09:29
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
We(1318) are doing a very similar thing but with AXIS cameras instead of a kinect because we did not want to run windows on our onboard computer and microsoft has rules about using the kinect with non windows devices
also we are using a PICO-ITX P830
Unread 16-02-2012, 19:27
Chris Marion
I should also note that we were about 8 pounds overweight as it appeared in the original photo; the kids have since re-designed the robot to weigh less while simultaneously taking 8 inches off of its height to help with the center of gravity. I personally feel that there were much better ways to go about reducing the weight and CG, because now our robot can only hold two balls, and three in a pinch. The students feel that we can make up for this limitation with our shooting accuracy, however.
