Re: Robot Motors Drifting?
From the TI Jaguar FAQ:
The way a deadband works is if a signal is within a range (say +/-5%) it outputs a zero. Otherwise it outputs the input signal. Pretty easy and then you don't have this to worry about again. |
This probably isn't an issue for you, but just in case: make sure your code isn't trying to control a Victor while you actually have a Jaguar installed, and vice versa. The "neutral" signals for each are slightly offset from each other.
To test the PWM signal to the motor controller: Hard code a zero speed command and let the robot sit enabled. If the motors do not run, your PWM is good. It seems we had to add a dead band so if the controller were close to zero it sent a zero command to the PWM.
If you can't figure out how to calibrate either the joystick or the speed controller, you can actually fix this through programming.
I'm not sure what language you're using, so here's some pseudo-Java Code:
// Teleop
final double THRESHOLD = 0.04;
double x = joystick.getX();
double y = joystick.getY();
if (Math.abs(x) > THRESHOLD || Math.abs(y) > THRESHOLD) {
drive(y, x);
} else {
stopDriveMotors();
![]() Hope this helps! |
