Go to Post "You fogot the gears!!!!" - The_Gman [more]
Unread 10-02-2012, 13:05
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Re: Weird fuse issues
I am not sure I follow. Our pressure switch doesnt have a pwm cord going to DIO.
Now it does not work no matter where the fuse is. And yes, the pressure switch did work in the previous arrangement. It would reach about 120 and then shut off.
Even though it does not work now, if I unplug the fuse while the bot is running the spike will flash green for half a second.
