Go to Post Our behavior – both good and bad – is contagious. Set a good example, behave in a mature, reasoned, professional manner and we will find that others around us will too. - dlavery [more]
Unread 09-02-2012, 12:35
Whateveryousay's Avatar
Whateveryousay Whateveryousay is offline
Team 1683 Techno Titans
AKA: Tony Chen
FRC #1683 (Techno Titans)
Whateveryousay is an unknown quantity at this point
pic: Team 1683 TechnoTitans Base and Ball Collector
Unread 09-02-2012, 12:36
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: pic: Team 1683 TechnoTitans Base and Ball Collector
Bridge bot? We had trouble with the andymark "8"" pneumatic wheels NOT being 8" and having trouble going over the barrier.
Collector and base look awesome. Very clean.
Unread 09-02-2012, 12:52
AKA: Tony Chen
actually. we can go over the barrier, we just cut the frame a bit, right now we are just 4 and 1/8 inches off the ground, which allows us going over the bump quite smooth actually
2011 Peachtree Regional Innovation in Control Award
2011 Peachtree Regional Semifinalist
2010 Peachtree Regional Champion
2010 Peachtree Regional Creativity Award
2008 Peachtree Regional Finalist
2007 Bayou Regional Champion
2006 Peachtree Regional Finalist
2005 Peachtree Regional Quarterfinalist
Unread 09-02-2012, 18:11
BlacksmithWoods's Avatar
BlacksmithWoods BlacksmithWoods is offline
Mechanics / CAD
AKA: Brendan Woods
FRC #0806 (The Brooklyn Blacksmiths)
BlacksmithWoods is on a distinguished road
By the way how was your turning? My team used the pneumatic wheels, and we had a rough time turning so we had to change things up a bit.
2002 - Present FRC (806)
Keeping It Stupidly Simple since 2002
"You are done with designing something, not when there's nothing more to add, but when there's nothing left to remove." - EricH
NYC FRC STLA (2011- 2014) Practice Field / Alumni Relations
Unread 09-02-2012, 18:38
AKA: Tony Chen
Our wheels are center dropped, so we had no problem with turning, we can do a 360 even on the carpet.
Unread 09-02-2012, 19:04
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
We're doing wide-base 4-wheel and turning is fast. With six wheels you should be immovable.
Unread 09-02-2012, 19:13
AKA: Tony Chen
as i said, center dropped 6 wheels, at any time, we only have 4 wheels on the ground, and we can do 360 even on the carpet, i dont think i will consider that immovable
Unread 09-02-2012, 23:00
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Sorry, I meant under the influence of another robot!
Unread 10-02-2012, 00:16
AKA: Tony Chen
oh, i see. But previous years we have been using the same design, we were always one of the best defensive robot at Peachtree Regional, pushing was not an issue for us at all
Unread 10-02-2012, 00:45
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
How's 6 wheel drop working out for aiming? I can imagine the rock would throw off aiming, although I'm not sure how much it would throw it off if you're doing manual instead of automatic
Academic Student (Forever)
Unread 10-02-2012, 09:14
Jedward45 Jedward45 is offline
FRC #2220
Jedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant future
What is the drop of the center wheel? As a note of caution, our team used a similar setup with 6 pneumatic wheels and a 1/4" drop in the center wheel. We were able to pivot on a dime while testing, but once we added all the weight of other components, we found the compression in center wheel eliminated the drop and made turning almost impossible. (The lateral coefficient of friction on those wheels seems to be rather high) Have you gotten around this problem?
Unread 10-02-2012, 13:30
AKA: Tony Chen
we just encountered this problem, any good suggestions?
Unread 10-02-2012, 13:58
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
We ran into this last year.
A few solutions-
1.More tire pressure.
2. Shorten the wheel base by drilling a couple of new holes.
3. Change one pair, or both pairs of the outside wheels to something with less friction like KoP wheels.
4. Gear your robot for more torque.
We ran into two problems when we did this. The robot would either refuse to turn, or the robot would execute a bouncy turn.
Refusing to turn usually means you have a long way to go to get it to work. Bouncy turns usually means you aren't far from non-bouncy turns. We deemed the occasional bouncy turn to not be a problem and moved forward.
Best of luck to you.
-Jeff
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
