Go to Post I have no clue. All I know is that every year the riddle in the clue has confused me but this year it is the lack of confusion that confuses me. - hallk [more]
Unread 10-02-2012, 12:22
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Lowering the speed of a motor threw a victor jaguar
How do we lower the speed for a motor using a victor jaguar. We are using this motor for a robotic arm. We are using LabView.
Thanks for your time
Unread 10-02-2012, 12:41
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Lowering the speed of a motor threw a victor jaguar
What do you mean you have a Victor Jaguar?
You only need one or the other, you don't use both together.
Unread 10-02-2012, 13:00
FRC #4166
Just a victor.
Unread 10-02-2012, 13:06
AKA: Matt B
FRC #1771 (1771)
Then (I don't know LabView) but give the Victor a different value. It should be something like -1 to 1, with -1 being full reverse, 1 being full forward.
Something like .5 would be half speed.
Unread 10-02-2012, 14:36
Depends on your control method, but you can multiply a Joystick axis value by a percentage (e.g., .9 or .75) before it goes into the Motor Set Output.
Then max power will be limited (e.g., to 90% or 75%).
Name:	Cut Motor Power.png
Unread 10-02-2012, 15:09
FRC #4166
Thanks for the advise. We will try it.
John
Unread 10-02-2012, 15:36
FRC #4166
The two small wires on the victor I am assuming are to power the fan. Where would you recommend wring those. We were thinking they should be wired on the power side of the victor, but not sure.
thanks
jalmos
Unread 10-02-2012, 15:43
You've got it. They wire into the power side of the Victor.
They should be on all the time keeping things cool whenever the robot is powered.
