Go to Post I would contend that you cannot have a consistently good robot without equally good teambuilding. - jonathan lall [more]
Unread 10-02-2012, 15:29
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: "cannot be resolved as a type" Error
"X cannot be resolved as a type" errors are commonly caused by two reasons:
1. Missing import statement, wrong package.
2. Referring to a type that doesn't exist.
If you are using an IDE, there should be a way to automatically remedy this.
Also, doesn't Java make your implement all the methods of the abstract class?
    protected void execute() {
    protected boolean isFinished() {
    protected void end() {
    protected void interrupted() {
