Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 10-02-2012, 15:48
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Java to Crio Downloading Issues
Originally Posted by austin1743 View Post
so we fixed the ip address issue (thanks for the help)
now we got another issue (lol)
we are getting an error where it says looking for frc_2012_v43.zip but got frc_2011_v28.zip
we tried looking for where it is calling for this file path but we couldn't find it... our netbeans is updated to the fullest and has all of the plug-ins installed...
Two things you should try:
1. Update your cRio flashing utility. The 2012 version has some major changes done to it.
2. Uninstall, reinstall the plugins in netbeans. Those plugins *should* contain the cRio image files.
Unread 10-02-2012, 19:40
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
ok the flash utility is just the cRio imager correct?
our netbeans is currently up to date with all of 2012's updates for frc.
will keep you guys informed..
we are using wired connection right now and trying to get that set-up before wireless...
Team 1743
Head Programmer
