Go to Post "Oh, the farmer and the cowhand can be friends, la la la..." - Andy Baker [more]
Unread 25-01-2012, 08:45
AKA: Brad
#0190 ( Gompei and the Herd)
SmartDashboard video
The SmartDashboard is intended to be a really cool tool for debugging and monitoring your programs output. There's a video of it being used for displaying robot data, status, and other things here:
http://www.youtube.com/user/BradAMiller/
Although it's being used from a Java program, the same methods work in C++. To use them, get an instance of the SmartDashboard class using:
SmartDashboard *sd = SmartDashboard::GetInstance();
Then you can call the methods like this:
sd->PutData();
etc.
Everything else in the video is language agnostic.
I hope this helps.
Brad
Brad Miller
Robotics Resource Center
Unread 25-01-2012, 09:43
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
Re: SmartDashboard video
Brad,
This is such a great improvement to the control system.. Being able to view our encoder speeds and status of switches makes debugging a million times easier.
We've got a speedometer and some booleans loaded up and once we figured out we had to put the team number in the dash, they all worked like a champ. Thank you!!!
-Dan Roswell
FRC Team 2370 Mentor
Unread 25-01-2012, 09:47
Jared Russell's Avatar
Taking a year (mostly) off
Great videos. Thanks Brad!
Unread 27-01-2012, 10:16
dkearle's Avatar
dkearle dkearle is offline
Dianne
FRC #1280 (Ragin' C-Biscuits)
dkearle is an unknown quantity at this point
The video is a great demo of some of the SmartDashboard features. I would love to see the next in the SmartDashboard demo video series cover PID tuning using the SendablePIDController. We are attempting this but ran into a problem where we typed in a new value for the P constant in the SmartDashboard PID widget and then hit the [ENTER] key, which of course immediately disabled our robot. It looks as if in your video you also inadvertently disabled your robot by hitting [ENTER]. I'm reading through the forums but haven't yet seen any other discussions on this that help me understand how we can enter data (not just a mouse click) on the SmartDashboard without hitting the [ENTER] key on the driver station. Any suggestions?
Another really, really useful SmartDashboard demo video would be a demonstration of an image targeting extension where the results are communicated back to the robot.
Unread 10-02-2012, 12:39
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Thumbs up Re: SmartDashboard video
Brad, I'd love to see a demonstration of how to display processed images on the smart dashboard if it's possible.
Or how about a sample video on how to proceess vision on the ds and send the data back to the robot?
Also, I think I saw OpenCV being installed with the smart dashboard, why and are there vision capibiliteis that we should know about?
Just some ideas, the smart dashboard video was awesome!
Unread 10-02-2012, 12:49
Brian Selle's Avatar
Brian Selle Brian Selle is online now
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Would it be possible to display an image on the SmartDashboard that was processed on the cRio? Would be nice to have a method like SmartDashboard.putImage("MyProcessedImage", myImage).
Unread 10-02-2012, 13:07
Right now we are processing the image on the cRio, saving it to the cRio and then using ftp to get the image and look at it. I've been toying with just automating this... push a button on the SmartDashboard, get the image using ftp and displaying it using a custom widget. Anyone done anything like this?
Unread 10-02-2012, 14:12
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
We have been saving the processed images on the cRIO as well. But we ran into several problems. If we did processing using the HSL color space, binImage->Write will fault. If we used RGB color space, the images were saved but they are all black. Is there a trick to save these images and are viewable? It would be wonderful if we can stream the processed images to either the Dashboard or the SmartDashboard. But looking at the current SmartDashboard support, I don't see any.
Unread 10-02-2012, 15:24
Try saving as PNG or BMP instead of JPEG.
Unread 10-02-2012, 15:56
mikets's Avatar
Software Engineer
Do you mean binImage->Write("/convexImage.bmp")? I saw the other thread suggesting that. So I was assuming that the Write function is writing the file in BMP or PNG file format. So at one point, I renamed the convexImage.jpg to convexImage.bmp and tried to open it that way. It was still black. However, I did not try doing binImage->Write("/convexImage.bmp") in the code. May be I should try that in case the ImaqWriteFile function actually looks at the file extension and decided to do something different.
Unread 10-02-2012, 16:58
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Yes indeed - the extension you put in the filename for the Write() function actually implies to that function what format it should write the image in. We found this out by experimentation and had luck getting from black JPEGs to useful BMPs.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 15-12-2012, 01:54
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
I do very much agree with this. The only reason I really want to use a custom dashboard is because I need to debug my vision tracking code.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
