Go to Post My father taught me long ago that how we respond to adversity is what defines us as human beings. Let's all keep this definition in mind as we move forward to change a culture. - Rich Kressly [more]
Unread 10-02-2012, 20:30
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Problems using CAN with PID
Originally Posted by gpetilli View Post
Agreed you must switch to kSpeed. You will need different P I D numbers when you switch to kSpeed. For tuning speed mode, start with the I number (not P as you would for kPosition). Once you have an I you like, you can ramp up P to tame minor oscillations. Always set D to zero in speed mode. There are several posts which give more details on tuning CANJaguar kSpeed controllers.
Wait a second. Why does D have to be set to 0 in speed mode? Ours seem to work best with P=.700, I=.085, D=5.000
Unread 11-02-2012, 20:25
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
It varies, there are different strategies. This year I've had good luck with speed control using the Ziegler-Nichols method (search it) with P and I (no D).
