Re: Wireless Bridge Setup [Help Needed]
Thank you for the help, but that was information I already knew. I'm using the router to extend the WiFi as the Classmate will most likely loose wireless signal when it is further away from me while driving at competitions. I read up on the Getting Started, and it only told me how to set up the D-Link. Any idea(s) that might help to get the router to be used to further the signal so we don't just have our robot dead on the floor? Thanks for the help!
EDIT: We can already connect to run it with the Classmate, I am just trying to work on a way to use the router to expand the signal for farther distances. Brandon Team 1025 |
Well, you must know that you can't use your extra router at competition, right?
As far as using it goes, you can change your DLink to bridge mode, and set it to use the same SSID that your other router is set for. Also set them to share common bands, and keep the security settings compatible. Here are some robot network variations you can use. |
This is my first year, didn't know. Thank you for all the help
In competition we will only use Ethernet cables to connect our Classmates to our robots in the pits and on the fields:
it is needed for practice driving and practice competitions. the range of them classmate directly isn't all that great, and at the practice comps, the boost in signal strength provided by the router well be very helpful in preventing dead/uncontrollable robots
