Go to Post I knew that the students on our team really understood what FIRST was all about when, two years later, our unofficial team motto changed from "we want to BEAT Chief Delphi" to "we want to BE Chief Delphi." - dlavery [more]
Unread 10-02-2012, 21:51
ben_benavides ben_benavides is offline
FRC #2085
ben_benavides is an unknown quantity at this point
Convex Hull Produces Black Image
OK so our team is having some trouble with image tracking. This is our algorithm so far.
Capture Image->Color Plane Extraction->Threshold->Convex Hull.
We are able to to capture the image in code, apply the color plane extraction, and the threshold. We are having trouble with the convex hull. Every time we try to apply a convex hull It gives us a black image. We are retrieving the images by FTP'ing into the cRIO. Any help would be appreciated.
Unread 11-02-2012, 00:29
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Convex Hull Produces Black Image
From my experience, a binary image is stored as a grayscale image with values of 0 and 1. Since grayscale is usually 0 to 255, it's impossible to see what is 0 and what is 1. So I usually put it into mspaint and then use the color fill to get it. Of course, that's harder to do if you have lots of small particles and such.
Unread 11-02-2012, 09:01
I agree with the other post. Use the particle analysis step to see if there are particles and what measurements you have. Although, debugging vision code without being able to see images is not my favorite pastime.
Greg McKaskle
Unread 11-02-2012, 15:25
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
If you save them as .png they should open in windows picture viewer. On my computer they show up as red.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 11-02-2012, 16:57
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is online now
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Yes - when you do the image->Write() function, if you use a .jpg filename, you'll wind up with black images often (or always). If you use .bmp, you'll wind up with usable files/images. And the other person said .png which I haven't personally tried.
.bmp
or
.png
Let us know this solved it.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 11-02-2012, 18:20
FRC #2085
Smile Re: Convex Hull Produces Black Image
Thanks for the help. We have successfully applied a convex hull and we are on our way to finishing vision tracking.
Unread 12-02-2012, 12:08
GrimmReaper's Avatar
GrimmReaper GrimmReaper is offline
FRC #2046 (Bear Metal)
GrimmReaper is on a distinguished road
I hadn't tried a BMP or PNG file, but rather just converted the image(changed the contrast and gamma) so that i could see the contrasting pieces and saved that as a JPG, so here's another example for ya, this results in a white on black image:
		Image* thisImage = myBinaryImage->GetImaqImage();
		BCGOptions bcg;
		bcg.brightness = 128.0f;
		bcg.contrast = 89.0f;
		bcg.gamma = 0.1f;
		if (imaqBCGTransform(thisImage, thisImage, &bcg, NULL) == 0)
			//error during save
			printf("Error with imaqBCGTransform : %d\n", imaqGetLastError());
			return ERROR;
		if (imaqWriteFile(thisImage, "/BinaryImage.jpg", NULL) == 0)
			//error during save
			printf("Error saving image : %d\n", imaqGetLastError());
			return ERROR;
- Jon
