Go to Post (middle school age) One time I had a truly awful day at school and came home crying. My mother's response? "Do you want to go to the build session tonight? It will make you feel better.." And it did. It always does. - rachelholladay [more]
Unread 10-02-2012, 11:11
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: pic: Wheel
Despite the obvious comments of "why?" and "where is the chamfer?", I must say that this looks like a very fun CAD and machine job! I give you many props for pulling it off!
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 10-02-2012, 13:47
Back after 4 years off
FRC #5279
Re: pic: Wheel
Originally Posted by Kevin_Morris View Post
Not to give the textbook mentor answer, but if students learned in the process, I see that it has more benefit than just weight saving. If they didn't... well it's still pretty nifty.
I agree to an extent that projects for the sake of learning are great but one of the biggest lessons to teach students is how to compare solutions (time, complexity, cost, weight, etc) to choose the appropriate one.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 11-02-2012, 04:39
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: pic: Wheel
I too was wondering why the rim thickness was kept so thick, until I realized the center spokes of the wheel are only about 3/4" or so wide (relative to wheel width). I also realized that's what you meant by "a lot of material was removed from the back side".
The outside of the wheel is really not that thick if you look at this picture you will get a better idea of why you thought it was. The spokes are only 1/4" wide. When I said remove material on the back side it was to take the OD of the part from 3.75 to the OD of the sprockets at ~2.15"
I understand cost benefit analysis. The addition of the double sprocket added only 30 min to the total cycle time of the wheel. In that added 30 min a total of 26 individual components were removed from each wheel (assuming the use of individual spacers). In the end its a simple and elegant solution to making a wheel and sprocket assembly simpler.
