Go to Post Pursue your passion whatever that may be and do not fault another for pursuing theirs. - Mr. Van [more]
Unread 11-02-2012, 05:23
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Re: Welding Right Angles
Clamp in place on a flat surface, metal tables are best -> Tack a corner -> rework the angle -> tack a second corner -> fix again ->tack a third -> Check again -> finish the weld. This should fix any angle issues. Our drive base is always welded in one pass (~2 hours of welding and reworking angles) and we have not had much of an angle issue over the past 2 years. As for warping, we have had metal bow in on our chassis by about 1/32 inch per 36 inches, just use some heat and bend it back to where you want it.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
