Go to Post FIRST doesn't end after high school, for some of us, it is only beginning. - David Kelly [more]
Unread 10-02-2012, 19:13
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Stuck Basketballs
I've checked over the Arena portion of the rules. It seems as if basketballs could get stuck under the bridge. If they do, we will be unable to remove them, it seems, since the appendages are limited to 14'', and there's 41'' of bridge on either side of the bump. I may be misreading things, but if I'm not...
Will this happen?
Will we still be able to "balance" on that bridge?
What can we do if this happens?
Will this affect us?
What will the field guys do about this?
Do we need the GDC here?
If I am misreading, sorry for the waste of time. If not, please help me puzzle out this seeming conundrum.
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
Unread 10-02-2012, 19:17
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Stuck Basketballs
Check out this youtube video. There is a part of the bridge that has been added, so that doesn't happen.
http://www.youtube.com/watch?v=-AMaq...T zjcT6bCAp-s
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 10-02-2012, 19:18
Xeneria Xeneria is offline
AKA: Sean Kim
FRC #2537 (RAID)
Xeneria is an unknown quantity at this point
I believe there are mini polycarbonite ramps underneath the brdige to stop the balls from being stuck under it.
Raid 2537
Unread 10-02-2012, 19:25
Da' Rule Man
AKA: Nik Shepherd
Thank you, I get it now. Didn't see the ramps in the copy of the Arena rules I downloaded, so I worried. I appreciate the C.D. guys' (and girls' [No sexism in F.I.R.S.T.!]) help.
Unread 10-02-2012, 22:20
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Balls can, and will, get trapped under the bridge. The only way to clear them is to tilt the bridge. If you can only push the bridge down, then you must clear the ball from the other side of the bridge.
I forsee teams that can only traverse the barrier using the bridge getting trapped and be unable to balance at endgame.
___________________
- Tennyson, Ulysses
Unread 11-02-2012, 07:46
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
There was also mention of other places in the field (baskets) and not being able (allowed) to clear them. I'm afraid that I don't remember the reference.
