Go to Post I've never been one for the "you did your best" and other "everyone's a winner" sayings, they don't push you, they don't get you to analyze what went wrong and figure out where to improve. - Aren_Hill [more]
Unread 11-02-2012, 11:25
shanaynay shanaynay is offline
shanaynay is an unknown quantity at this point
AxisCameraException
Hey, we are trying o track using java, but anytime we try, it stops at colorImage img = camera.getImage(); and throwing axiscameraexception because this line apparently does not work. Any suggestions?
Unread 11-02-2012, 13:15
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: AxisCameraException
The line works if you are getting an AxisCameraException.
The problem is with the cRIO not being able to contact the camera. Get your development computer onto the same network and try to ping it. Also, make sure that you've read this file on how to configure your camera correctly (especially the part about the proper username/passwords)
