Go to Post cue Dave Lavery with some witty response - Taylor [more]
Unread 04-01-2003, 17:55
Eugene Eugene is offline
#0321 (Lancers)
Eugene is on a distinguished road
Send a message via AIM to Eugene
Lightbulb Changes from last year
Since most of the veteran teams know the kit of parts and the general rules by heart, I think it would be beneficial for us to highlight any major changes in this year’s game.
Eugene
Unread 04-01-2003, 18:18
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
I'm certaintly no expert but this is what I can tell you.
Drill motor is beefed up.
Robot starting positions have moved to center field
Human player interaction has decreased
Pre-Fabricated motor mounts are great and new
Automation of robots is new
Scouting is going to be mega hard this year
Crates instead of balls is new, and kinda weird I think
The rule manual is smaller than I remember(could be wrong)
Brute force won't be as much of a factor as in recent years(i think)
and finaly
Dean wasn't on a segway, I haven't seen him off one since it was invented.
Hope that helps
College and its wonders. First year and alot of other FIRSTs.
Unread 04-01-2003, 18:23
Matt Reiland's Avatar
'The' drive behind the drive
Some of the other rather large changes are that you can buy belts and wheels from any source according to the manual. We used to be limited to Skyway.
Also we are back to the price limiting factor $3500 which is supposed to include all machining and fabricating money that the team spends outside of team members (This one I have a feeling may get abused)
New is the ability to buy fabricated gearboxes and other items off the shelf if I read correctly in the manual.
One rule I will have to get clarification on is the addition of traction material to the outside circumference of the wheel appears to be not allowed, it is underlined you can only remove material from the outside of the wheel.
Unread 18-01-2003, 12:32
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
PAGE 20, RULE M17
This rule was drafted to attempt to prevent damage to our playing field, which includes the
ramp structure, field borders, etc. Because we allow you to fabricate a wheel, it really doesn’t
make much sense for us to say:
“The outer surface of off-the-shelf wheels may be modified by removing tread material only.”
Please delete this sentence; however, now we need to address the issue of “anti-traction”
devices or anchors, i.e., devices designed to hold you firmly in one place. Anchors cannot
use metal in contact with the carpet to “stay put.” Similarly, metal traction or anchor surfaces
are not allowed on the ramp surfaces.
Add the following to Rule M17:
Anchors, i.e., devices that are deployed/used to attempt to keep one’s robot in one place and
to prevent from being moved by another robot, cannot use metal in contact with the carpet to
“stay put.” Similarly, metal traction or anchor surfaces are not allowed on the ramp or
platform.
simply put team update #4 says you can add to the outside of off the shelf wheels as long as the eheels do not damage the playing field.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 18-01-2003, 12:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We can buy pretty much anything we want as long as it's not restricted or too expensive. (or breaks a rule)
Way cool kit of parts.
No seat motors.
3 different traction surfaces.
Unread 19-01-2003, 17:18
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
The cim motor's rpm is a lot lower (from ~5500 to ~4500 don't remember exact specs) but since you can use the one from last year it doesn't matter much =P
Unread 19-01-2003, 23:51
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
I think those big aluminum "blocks" they gave us this year are completely useless. They're so very heavy.....I know my team sure isnt using them.
I think its good the Van Door motor is back....and its nice they've opened up the parts this year (u can buy more things), and the cost limit is pretty good (not too high, or too low).
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 20-01-2003, 09:36
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
From Update #2:
You can use motors from previous years IF AND ONLY IF they are exactly the sameas this year’s motors. For example:
› You can use last year’s CIM (Chiaphua or Atwood) motor even though the output shaft is different this year;
Unread 20-01-2003, 11:44
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Those aluminum blocks (the hexagon ones I assume) are extremely useful if you want to use the pre-fabricated gearbox! Cut them to size and bore out whatever you want for an input shaft! Once you cut them down and bore them out, they are extremely light....
Anyways, they are useful if you intend on using the prefab gearbox.
This year's CIM is 5342 RPM Free Load.
~Adam
Championship Qualification - How you would've done it Ken Leung Championship Event 6 26-10-2003 14:00
New year, new ideas!! Tyler Olds 3D Animation and Competition 3 08-10-2003 00:23
Great year. archiver 1999 0 23-06-2002 22:46
Wow! what a year archiver 2000 8 23-06-2002 22:43
2000 not a new Millenium archiver 2000 7 23-06-2002 22:17
