Go to Post Glitter… lots of glitter. - Andrew Schreiber [more]
Unread 09-02-2012, 17:51
Tzaddik Tzaddik is offline
FRC #3267
Tzaddik is an unknown quantity at this point
Dashboard Update?
So I've been hearing that if the dashboard is updated properly that there should be a compass in the corner showing the gryo angle. Our dashboard doesn't have this compass, but it does have a kinect skeleton tab which means that it has to have been updated at least somewhat. I'm wondering if someone could link this new update or something because our camera is not able to connect and show up on our dashboard. We have done everything we can as far as the camera connection so this is the only other thing I could think would be preventing it from working. Thanks!
Unread 09-02-2012, 19:17
Re: Dashboard Update?
The dashboard with the gyro display is now several years old. The 2012 dashboard has a tab control around the camera, and in the other tab it has the Kinect display.
Greg McKaskle
Unread 09-02-2012, 20:16
Did you run the 2012 camera configuration utility? Did you plug the camera into the dlink bridge?
Unread 11-02-2012, 12:59
FRC #3267
If you mean the axis camera setup, yes we have run that. We had the camera connected to the second ethernet slot of the cRio, not the bridge. Could that be a problem?
Unread 11-02-2012, 13:02
FRC #3267
Okay, it's all working now. I guess we couldn't have it connected to the cRio ths time. Thank you very much for the help!
