Go to Post It is an honor and a privilege to be associated with such an outstanding group of people. And Arefin. - Gary Dillard [more]
Unread 11-02-2012, 11:17
nonamedude nonamedude is offline
FRC #1815
nonamedude is an unknown quantity at this point
Best Settings for the Camera
Hey guys,
What do you think is the best setting in terms of exposure brightness and stuff for the axis camera so that it detects the retroreflective tape while a bright light is shined upon it?
Unread 11-02-2012, 13:18
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Best Settings for the Camera
The default stock settings worked fine for us. A lot of this should depend on your setup and code (threshold...etc).
Unread 11-02-2012, 13:41
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Why don't you try and find out yourself? Everyone's values are going to be different, it takes about 5 minutes with a light and some tape set up to see what makes it show up brightest.
Unread 11-02-2012, 19:21
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
We are using a red LED ring from superbrightleds.com (AE60-R15, like the one from AndyMark but red), and a Axis M1011 camera.
The normal settings was unusable; the reflection was so bright that it was saturating and looked white.
I think I've settled on (50% is default):
Color level: 100%
Brightness : 25%
Sharpness  : 50%
Contrast   : 50%
White balance: Fixed Fluorescent 1
Exposure value: 20%
Exposure control: Automatic
We had the brightness as 10%, which worked great, but couldn't pick out the target from farther away.
However, you should play with these yourself, It's pretty easy to tune it live with the web interface for the camera. Look at the sample images from NI (for example, the ones in the Java sample program) for what the image should look like. Mostly black, with a *bright* target.
