Go to Post Unfortunately our team missed out on a great opportunity to "learn from the pros" because we did student-centric things like insisting on having a student field coach. - Tom Bottiglieri [more]
Unread 11-02-2012, 10:49
BoltAction BoltAction is offline
FRC #1009
BoltAction is an unknown quantity at this point
Java to CRIO connection problems
We have been trying to upload the code to the CRIO for 3 days now. We keep getting errors. We have already tried reimaging the CRIO but still getting the error.
We are using direct connection between the CRIO and the laptop.
The laptop's ip: 10.10.9.6
subnet: 255.0.0.0
Gateway: 10.10.9.4
This is the error we keep getting:
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) 64-Bit Server VM 22.0-b10
Target IP: 10.10.9.2
Network interfaces on host:
Intel(R) 82579LM Gigabit Network Connection: address: 10.10.9.6 netmask: 255.0.0.0 <--- on robot's subnet
1x1 11b/g/n Wireless LAN PCI Express Half Mini Card Adapter: address: 192.168.2.7 netmask: 255.255.255.254
Connecting FTP @10.10.9.2
C:\Users\Karan Thukral\sunspotfrcsdk\build.xml:96: The following error occurred while executing this line:
C:\Users\Karan Thukral\sunspotfrcsdk\ant\upgrade.xml:40:
java.net.SocketException: Software caused connection abort: recv failed
Someone please help.
Unread 11-02-2012, 13:26
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Java to CRIO connection problems
This seems like an issue with communicating with the cRIO.
Troubleshooting steps I would take:
1. Turn off the firewall, all of them.
2. ping 10.10.9.2
3. ftp 10.10.9.2
4. Reinstall the Netbeans plugins (completely remove and reinstall) or upgrade them. It might be the case that the cRio is updated and the plugins are old. Or maybe the plugins are updated and the cRio is old. Make 100% sure that both of them are updated to the newest version. (You'd be surprised how many people with problems will tell you that everything's updated and they're not.)
If all this fails, then I would suggest trying to isolate the cause of the problem by putting the code on another computer and trying to upload from there OR to upload onto another cRio (if you have one).
Unread 11-02-2012, 13:52
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Try changing your netmask to 255.255.255.0.
