Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 11-02-2012, 14:00
BMotl94 BMotl94 is offline
FRC #3965
BMotl94 is an unknown quantity at this point
Motor Question
Hello we have recently created a little program in teleop that will take the input of button one through a boolean and then set the output of the motor. The question we have is how the cRIO will know which motor to send the values to. We want to do this without a jaguar. It just needs to be one speed. So how do we go about specifying which motor the joystick will control.
Unread 11-02-2012, 14:07
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Motor Question
You'll need to use the Spike controller in this case.
Unread 11-02-2012, 18:27
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Motor Question
And in the case of Labview, you'll want to program them using the Relay.vis and Relay Switches on your Digital Sidecar! ;D
