Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread 11-02-2012, 13:14
Quellek2 Quellek2 is offline
FRC #4121
Quellek2 is an unknown quantity at this point
Exclamation More camera issues. ugh
Our team can not seem to get the vision part of our main to work. Here's what we have now.
However, we can not get it to output an image. Any suggestions?
Unread 11-02-2012, 13:37
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: More camera issues. ugh
You've wired a True constant to your While loop, causing it to stop immediately.
Unread 11-02-2012, 13:58
FRC #4121
well, that was a stupid mistake. However, it did not fix the problem
Unread 11-02-2012, 14:09
FRC #0023 (PNTA)
Rookie Year: 1620
So, you want to view the processed image along-side/instead of the original camera image, yes? Have you edited your Dashboard to display this?
Unread 11-02-2012, 14:13
FRC #4121
No, our goal here is to just get the camera working. We know how to do the tracking, but we can't get the camera to send an image to the tracking sub-vi. So we just created a display to see if anything was there, and we found that nothing was happening ever.
Unread 11-02-2012, 18:59
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Try copying in the NI example into a robot project. There should be an example on how to do this in the tutorials included with LabVIEW.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 11-02-2012, 20:24
I do not see a parallel MJPG loop in the VI. Technically the VI can be in other VIs, but in the framework code and in the vision examples, it is was placed near the loop in Vision VI. The VI is on the bottom row of the palette and is called Acquire MJPG Loop.
Greg McKaskle
