Go to Post Leave FIRST? That's an option? =) - treffk [more]
Unread 11-02-2012, 15:29
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Robot Signal Light
I am probably sure everyone has seen this problem:
My electronics board works and the digital sidecar has the blinking. When the Robot Signal Light is plugged in, it doesn't flash?
Set-Up:
(+)_________________________
(-)-------------------------|light___|
I bridged the Voltage into the side inputs and Ground into the center input.
I have plugged the light in both directions and I have used the old and new light.
Any insight, advice, commentary, hi-fives, comments, criticism, or any other way of saying "Hey try this" will be much appreciated.
Thank you in advanced and Happy Competition!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 11-02-2012, 15:54
TubaMan TubaMan is offline
FRC #1723 (First Bots of Independence)
TubaMan is an unknown quantity at this point
Re: Robot Signal Light
Did you check the wires or the connection from the wires to the sidecar and to the light itself?
Unread 11-02-2012, 18:18
Student
AKA: Marco Schoener
I was thinking of that while typing the htread. I will try that on Monday next meeting.
Thank you for your input!
Team 1369
Senior
Head Electrician
Unread 11-02-2012, 19:01
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
When the robot turns on, does the RSL just stay off? Does it rapidly blink as the side car does? We've found that sometimes the RSL has a little bit of lag behind the rest of the robot. Not entirely sure why, now that I think about it...
Academic Student (Forever)
Unread 11-02-2012, 19:12
Student
AKA: Marco Schoener
The light just refuses to turn on at all. This is perplexing!
Team 1369
Senior
Head Electrician
Unread 11-02-2012, 19:18
CalTran's Avatar
MST Rolla Senior
Well, I would suggest, on Monday, taking a volt meter to the sidecar and checking if there is any output. (Or, if you don't have one, you could [in a pinch I've done this a few times] take a christmas light and see if it lights up.) After that, I would suggest checking the continuity of the wires, as well as making sure the la and lb are jumped together, and that the neutral goes to the center. Then, make sure none of the wires are crossing each other where they are hooked up. After all that, try a different service light or another sidecar. If possible, test it on somewhere that you know works (Like a programming testbed perhaps?)
Unread 11-02-2012, 22:08
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
There's a green LED light on the digital sidecar, right next to where you plugin the light. Make sure it's blinking. It blinks exactly the same way the RSL blinks.
Prototype, Prototype, Prototype
Unread 12-02-2012, 14:03
Student
AKA: Marco Schoener
The light on the digital sidecar does blink, which is why I am confused, so I am going to check its voltage with a voltmeter and get to the bottom of this mystery gang.
Thanks agin for the input!
Team 1369
Senior
Head Electrician
Unread 12-02-2012, 14:19
The green LFL ("little flashy light") LED on the Digital Sidecar is connected across the same pins that the amber BFL ("big flashy light") plugs into. If the green light blinks but the amber one does not, the second thing to check is the wiring between the connector and the light. You described it properly, but maybe there's a broken wire you can't see. Maybe you've accidentally caught some insulation instead of the conductor in the screw terminals of the BFL's plug.
The first thing to check is the 12 volt power to the Digital Sidecar. If it's not there, there could be just enough voltage sneaking in from the DIO module to make a few PWM outputs work, and to let the green LED flash dimly without being able to power the amber panel light.
