Go to Post The students who benefit from FIRST are the real "trophies". - David Brinza [more]
Unread 11-02-2012, 17:48
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Microswitch program..
Basically I want to press a button and let go but the motor begins to run until the switch is activated then I want it to roll back for 5 seconds. Can someone give me an example on how to do this using Labview.
Unread 11-02-2012, 17:58
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Microswitch program..
Is this what you are trying to accomplish? I think some other programmers on here could help out and also make sure I haven't made mistakes....
http://imgur.com/a/oSPD4
Unread 11-02-2012, 18:20
FRC #4210
Yes thank you..
Unread 11-02-2012, 18:32
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Originally Posted by Luiz12 View Post
Yes thank you..
I'm not sure it actually works, as I don't normally work with the wait.vi function so I'd build it up just to make sure.
Unread 19-02-2012, 20:20
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
make sure you don't put that in teleop. That wait will stall out the loop.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 19-02-2012, 20:29
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
He is correct... Perhaps a Elapsed timer would work better.
Unread 19-02-2012, 20:32
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
actually, you would do good to do it the way you have it here, but throw it into a separate loop in periodic tasks. There is no good way that I have found yet to do a delay on the cRIO without running it in parallel. Mainly because the timestamp is kind of flakey.
