Go to Post "It was defense killed the beast." - Justin [more]
Unread 11-02-2012, 17:29
jessemf jessemf is offline
FRC #2945
jessemf is an unknown quantity at this point
Bumper/frame question
from the bumper rules it states that the bumpers need to be at least 8" on each side of the robot... does this need to be a contiguous 8" or can it be split into two 4" pieces?
Unread 11-02-2012, 17:37
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Bumper/frame question
8" is the minimum length....look here:
http://frc-manual.usfirst.org/viewItem/57#4.1.6
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 11-02-2012, 17:38
Contiguous 8". Q&A has the following to say (among several other answers in the same vein:
Game - The Robot » Bumper Rules » R27
Q. Two teams have asked for the same information and you keep refering us back to the rules. If we have a U-shaped front on the bot can each leg be less than 8"? This appear to be an issue with rule R27. 8" required bumper from each eaterior vertice. Please clarify for multiple teams!
A. Per Rules [R27] and [R33] Bumpers must be at least 8 in. long and. and backed by rigid members of the Frame Perimeter on each end.
Q. Does the 8 in. of bumper required on each side of an exterior vertex have to be a continuous section or would multiple sections be legal as long as they totaled 8 in. per side? Can the “non-plywood backed” portion of the bumper mentioned in [G28] C be counted toward this 8 in. required by 4.1.6?
A. The 8 in. of Frame Perimeter immediately on either side of an exterior vertex must be covered by a Bumper.
Unread 11-02-2012, 17:52
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
There needs to be 8 inches of bumper on each side of each corner or vertex. So assuming a 4 sided robot, there needs to be a minimum of 16 inches of frame covered by bumper on each side. that minimum of 16 inches of bumper would need to be in two 8 inch pieces starting at each corner with a max 12 inch gap on the 28 inch side and a max of 22 inch gap on the 38 inch side.
2016 Central Illinois Winner. Curie Division finalist
Unread 11-02-2012, 19:41
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by BJT View Post
...there needs to be a minimum of 16 inches of frame covered by bumper on each side...
If you wanted to make a very small robot, with one side <16 inches, it would be legal, as long as it's at least 8 inches, and no breaks in between the corners. Each vertex would still have the minimum 8".
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 11-02-2012, 22:44
BJT's Avatar
BJT BJT is offline
AKA: Ben Thorsgard
Ya, true.
