Go to Post If only every team had a Wildstang programmer! - Jeremiah Johnson [more]
Unread 11-02-2012, 18:16
l0stboy l0stboy is offline
FRC #4064 (InZombiacs)
l0stboy is an unknown quantity at this point
Accelerometer java code problems. Returns zero.
* To change this template, choose Tools | Templates
* and open the template in the editor.
package edu.wpi.first.wpilibj.templates.subsystems;
import edu.wpi.first.wpilibj.ADXL345_I2C;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.templates.RobotTemplate;
import edu.wpi.first.wpilibj.Accelerometer;
* @author Developer
public class ADXL extends Subsystem{
public ADXL()
super("accelerometer");
protected void initDefaultCommand()
public void printAcceleration()
ADXL345_I2C.AllAxes aa = RobotTemplate.getADXL().getAccelerations();
System.out.println("X: " + aa.XAxis);
System.out.println("y: " + aa.YAxis);
System.out.println("z: " + aa.ZAxis);
here is our code. We're not sure why our accelerometer outputs zeros. Is it initialized right? Is there a better way to get the axis values?
We're calling it from RobotTemplate, where the accelerometer is initialized as:adxl = new ADXL345_I2C(1, ADXL345_I2C.DataFormat_Range.k2G);
We're wired to the I2C on the sidecar using a pair of double-female wires (0V,SCL,SDA,5V) so we're pretty sure we don't have wiring issues.
Pedro
Ocala InZombiacs
Unread 12-02-2012, 08:51
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Re: Accelerometer java code problems. Returns zero.
For what it's worth - we're having exactly the same problem. The connectivity in the wiring is there, the pin connections are correct, and the test code doesn't get much simpler. But it seems to be a common issue if you look at other threads.
Unread 14-02-2012, 05:59
AKA: Stu
For what it's worth - in our case, the fix for this was to switch from the 'round' cable to the ribbon cable in connecting the digital sidecar to the cRIO module. We did that and all of a sudden starting getting values.
We are using the older 8-slot cRIO, and two of the 3 wire PWM cables (with two wires in each) to connect the accelerometer to the I2C connection on the sidecar.
Our test code was pretty much the same as the first posting.
Unread 14-02-2012, 07:07
Intel i7 Intel i7 is offline
FRC #3540 (Wildcat Robotics)
Team Role: Driver
Intel i7 is an unknown quantity at this point
The weird thing is if I remember correctly our problem was fixed by switching to the flat cable, but nothing else worked with the flat cable for us
Driver
Programmer
Webcoder/Designer
http://www.chiefdelphi.com/forums/showthread.php?t=102329
Making our own custom dashboard system/framework!
Unread 15-02-2012, 15:16
We have always been using the flat cable, but the problem persists.
Pedro
Ocala InZombiacs
Unread 17-02-2012, 22:51
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
I had terrible issues trying to read the accelerometer. The eventual solution was to use a short I2C cable between the accelerometer and the digital breakout board. Keep it under 12", if that does not work make one that is 6" long and see if that help.
Good luck, I feel your pain
Steve
Unread 18-02-2012, 12:28
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
We had the same problem and switching to a ribbon ccable fixed it, but are you sure that aa.XAxis); is right? we do "x is" +accel.getAcceleration(ADXL345_I2C.Axes.kX); well about that,
Off to WPI!
Go OxBE4
